Fuel Tank Suddenly Reading Empty (After Scanner Error Code Reset)
Raward
Post by Raward » Fri Aug 01, 2014 5:02 pm
Ongoing problems with my X5....
After replacing my gearbox for nigh on 3K i decided to tackle an issue with the fuel guage.
It used to read full for a hundred miles or so then drop to about half way suddenly. Then it behaved itself for a while.
More recently I ran a scan and a fuel sensor error came up. I cleared the error and now the guage reads empty with the warning light and "BONG" every time I start her up! >:(
OBC now reads as pictured.
My local indie rubbed his chin and took a sharp intake of breath when I told him about it.
Strange it should work on and off?
Any thoughts would be helpful?
RAWImage
2003 X5 pre-facelift
Re: Fuel Tank Suddenly Reading Empty (After Scanner Error Code Reset)
Post by X5Sport » Fri Aug 01, 2014 6:06 pm
Bad wire to/from the sensor?  Unfortunately it's under the back seat.... :'(
AVI-8
Post by AVI-8 » Sat Aug 02, 2014 5:31 pm
Hi your OBC is telling you that there's no fuel in the left side and 17.9 litres in the right, sounds as though you could have a problem with one of the two sender units, if you've got an ohm meter you could check for correct resistance, I'm not sure what the correct resistance should be for full/empty readings perhaps an on
online search would tell you,
Also have a look at this.
http://xdrivers.co.uk/forum/https://xdr ... ic.php?t=6
Logan
Current
2006 X5 Le Mans Blue Sport Edition 3.0D
1991 Porsche 911 Carrera 2
