is it possible
Smeeagain
is it possible
on a 2004 E53 3.0 D to switch off the interior boot light when the tailgate is open, without pulling a fuse out? Is there a switch somewhere?
smee
smee
- Steamyrotter
Re: is it possible
When i need to leave the boot open i tend to flip the catch with a screwdriver which turns em off
you need to remember to 'open' the boot before closing though
Re: is it possible
Does it not turn itself off after a few mins? ISTR mine did, and the X6 does too. You may want it to happen quicker though.
Never anthropomorphise computers. They hate that.- Steamyrotter
Re: is it possible
Mine did once... but it was due to battery flattening.....!
Not sure if there is a setting for it.
Will have to have a nose.
Smeeagain
Re: is it possible
no it stays on - hence me wanting to switch it off as it just drains the battery if you're doing a job where the tailgate is open for a while
smee
smee
- Stevejspm
- Contact:
Re: is it possible
Change the filament bulbs for LED's, much less drain on the battery & looks nicer at night!
Smeeagain
Re: is it possible
Perhaps. But the point of the post is that I don't actually want them on ......
Smee
Smee
Re: is it possible
If the car goes to sleep then they should go out, but otherwise you'll have to fit a switch or fool the existing switch into believing the hatch is shut.
TimX5
Re: is it possible
[quote="Smeeagain"]
Smee
Neither do I , might have to fit a switch.
Smee
- Steamyrotter
Re: is it possible
Bugger the switch..
use post 2
the car even comes with the screwdriver to do it...
(cant believe i am suggesting simple solutions... must be ill... or more likely getting old!!!!!)
use post 2
TimX5
Re: is it possible
[quote="Steamyrotter"]
Bugger the switch..
use post 2
When I leave the boot lid up with the catch flicked over , our las has a habit of trying to slam it shut :chop:
Bugger the switch..
use post 2
