Instrument cluster display
Monty84
Post by Monty84 » Tue Jul 15, 2014 9:54 am
Is there a way to fix this, dessicants etc, or can this be replaced?
Instrument cluster display not displaying properly.Image
Owner of the Ultimate Labrador Carriage
2003/53 4.6IS E53
Re: Instrument cluster display
Post by X5Sport » Tue Jul 15, 2014 10:11 am
Have a look for cluster pixel fix on here.  It's a common issue.
Monty84
Post by Monty84 » Tue Jul 15, 2014 10:13 am
Cheers didn't know what wording to use, I have found many examples of lamp replacement but not the actual strip of LCD display
2003/53 4.6IS E53
Steamyrotter
Post by Steamyrotter » Tue Jul 15, 2014 10:12 pm
Its a ribbon cable issue normally.
They can be changed, depending on your abilities and bravery...
Or there are places that will do it for you.
I did mine and it makes all the difference.  Its all the little details that matter
Didn't take too long but did require drilling out parts of the dash as i didn't want to risk the dials by removing the pointers..
When its back together you cant see where it was drilled as long as you do it properly
Chrisw4266
Post by Chrisw4266 » Tue Jul 15, 2014 11:29 pm
Just done mine recently best bet is to buy the screen with the ribbon attached it's not to bad to fit. As mentioned you do have to drill the housing so if your not brave the have it done for you. Got my screen from eBay here's the one I used http://www.ebay.co.uk/itm/261508423936 the seller is spot on give him a call if your unsure of what kind of a job it is.
MrCam
Post by MrCam » Tue Aug 05, 2014 5:21 pm
I changed mine with one I bought from Ebay, it's an awful job 1st time around and the template they sent for drilling the holes didn't line up with my clocks, fortunately I checked the rear of the instrument to locate the screws and drilled it ok.
It's fiddly to say the least and it's one of those jobs that when I started I wished I'd just paid the £80 and got it done for me.
If I ever do another one I'll invest in a fibre glass pencil to clean the contacts on circuit board 1st to make sure it's properly clean.
Ryoken
Post by Ryoken » Sun Aug 24, 2014 8:54 am
im facing the same problem on my e53 at the moment , the lcd is terrible on mine , loads of pixels dead, I don't fancy doing it myself , has any one sent there's off to get repaired?.
I don't fancy sending my cluster off to just any one.
2002 e53 4.4  tempremental
Chrisw4266
Post by Chrisw4266 » Sun Aug 24, 2014 9:16 am
The seller I listed above seemed very good I was on the phone nearly an hour with him about doing the cluster myself. He was really helpful and they do work for the dealer network.
There no. Is on the ebay listing give em a call.
