I own a BMW X5 2001 3.0i. Yesterday I went on a long trip in the snow (during which i was more that impressed with the car's performace and handling) however I run into a couple issues. As I was driving I noticed that the temperature gauge went off the scale passed the red indication. I immediately pulled over and went to check the engine over but everything was fine. As soon as I restarted the engine the temperature gauge was barely coming out of the blue region. I then drove the car for another 70 miles and the temperature gauge did not move out of the blue zone at all. I put that glitch (the gauge going of the scale) down to the freezing cold affecting the sensor or something because it happened within seconds. However I then noticed that I couldn't get almost any hot air out of the car's heater. And the temperature gauge was sitting quite low considering the car was driving at 70mph for about two hours. I would expect that the engine would warm up and the heating inside the cabin would work normally. I appreciate that the weather outside is below freezing (-10 to -6 C) however I don't know if it justifies the low engine temperature. One of my thoughts was that the thermostat may have been stuck open causing the fan to work all the time. Is that something that might happen? Finally, are there glitches something that are a result of the cold weather or would you recommend taking to the dealers for a check up?? One note that I need to make is that I have never seen the gauge half way apart from when I am stuck in traffic for a long time. As soon as I drive away the temperature drops close to the blue region. Attached is the photo that I took after I parked the car.
