Do These Freeze up causing audible alarm to be on all time.
Reversed off the drive ok and went on the xmas run. When i got to location i stuck it in reverse and the sound was constant. I had a look and coudnt see anything on the outside of the sensors so i just presumed they froze @ -5
Parking sensors
- Sanj
Re: Parking sensors
Need to be dried out - the moisture may have got to them...
- Bungie
Re: Parking sensors
[quote=""Sanj""]Need to be dried out - the moisture may have got to them...[/quote]
I have read that somewhere, Was it you with the Hairdryer
I will see what happens over the next couple of days.
- Sanj
Re: Parking sensors
Yes.. well the weather causes havoc with the hair in this weather!
No - others have said the hairdryer is best option and then some sort of repellent...
Re: Parking sensors
[quote=""Sanj""]others have said the hairdryer is best option and then some sort of repellent...[/quote]
Certain members around here - not mentioning any names - appear to think being an E71 Owner is a form of repellent.
Re: Parking sensors
LOL! I for one would be in your gang- if only for more than the 4 seats...
- x555
Re: Parking sensors
[quote=""X5Sport""][quote=""Sanj""]others have said the hairdryer is best option and then some sort of repellent...[/quote]
The lot of them are all dodgy if you ask me
....i'm not jealous or owt mind
- x555
Re: Parking sensors
[quote=""Bungie""]Do These Freeze up causing audible alarm to be on all time.
Reversed off the drive ok and went on the xmas run. When i got to location i stuck it in reverse and the sound was constant. I had a look and coudnt see anything on the outside of the sensors so i just presumed they froze @ -5[/quote]
I think that they do freeze over and the thin layer of ice makes them beep constantly.
If one is damaged/broke it would show up with a diagnostics check and would beep on and off.
I don't know what's up with mine though as they have been beeping constantly even in the warmer weather....there getting right on my
now
- Bungie
Re: Parking sensors
Everything back to normal after a night's sleep
