Aircon hp pipe split today!! check your lines heads up to prevent failure!!
kjb1
Post by kjb1 » Tue Jun 24, 2014 7:36 pm
Well as title states.  Started the car today, and thought it was smoke billowing out from under the bonnet!! closer inspection revealed ( once pressure had died down ) that it was the aircon line ( i only re-gassed 3 weeks ago!!!!! ) that has been split by what looks like a poor design!! check your lines guys and put something underneath to support it.  The pipe has rubbed on a bare edge of body work and cut through causing instant failure of the line over no doubt a long period of time!! Phoned dealer, its £90 ( with dealer discount as good friend  works there. ).  Should have been £102!!!!! rip off!! but on back order world wide lol so delivery is 6 weeks!! here is a pic:
if you look its the line which has a flexi pipe in middle of it via a high pressure crimp, its been rubbed by the thin metal body plate bare edge underneath, located on left hand side of engine bay as you look at it.
Re: Aircon hp pipe split today!! check your lines heads up to prevent failure!!
Post by X5Sport » Tue Jun 24, 2014 8:18 pm
Nasty, and not something I've seen anyone on any forum I read report as a problem.  Glad no one was hurt and it's no worse!!
It could be incorrect fitting or damage caused to the pipe during a service (by perhaps a techie leaning where they shouldn't?) putting it too close to the metal underneath.  It may be that when 'correctly' installed there is no issue.  I would certainly have expected that there would be an air gap below any high pressure line - if that is anyone at BMW thought to check..... ;)
Can anywhere else supply?  Just thought you might need the fuses pulled to prevent compressor damage?  They are VERY expensive.. :'(
kjb1
Post by kjb1 » Tue Jun 24, 2014 8:45 pm
Ive knocked the compressor off straight away! its just bled away as pressure has decayed.  Its clearly a recognised issue as a backlog world wide for part being 6 weeks means its clearly in demand.  Check your lines with aircon on and engine running to check for vibration etc.
current calling breakers!!!
Post by Horizon » Wed Jun 25, 2014 7:14 pm
Try taking the hose off and going to your local hydraulic hose repairers. They will probably make you one up. :)
kjb1
Post by kjb1 » Wed Jun 25, 2014 11:45 pm
the the main line thats gone, not flexi.  Fab direct came through for me today however.
