Level system failure
pcdee
Post by pcdee » Fri Jun 13, 2014 6:47 am
Morning chaps
Driving to work this morning and 'bing'....'Level System Failure', nearly shat myself.
Got to work and the rear passenger side is lower.
X5 E70 3.0D SE
Re: Level system failure
Post by X5Sport » Fri Jun 13, 2014 10:46 am
Airbag puncture, level sensor?
pcdee
Post by pcdee » Fri Jun 13, 2014 11:59 am
Thanks Richard.
Anyway of telling?
X5 E70 3.0D SE
graemeX5
Post by graemeX5 » Sat Jun 14, 2014 5:41 am
I'm not sure if this would work but as the airbag is attached to the car if you spray the airbag with a strong mixture of water and washing up liquid any leak from the airbag would then create bubbles around it.
It's just that when my gas engineer friend cone roungpd he check for gas leaks in a similar way and if it works for that it's should work for the airbag and the connections.
Don't forget to dry it iff and be careful to keep it away from any electrics when checking the pipe joints or the pump on th car.
The alternative is take it to you local garage whether BMW or Indy
pcdee
Post by pcdee » Sat Jun 14, 2014 10:58 am
Thanks.
Definitely a leek. Gonna see if warranty direct will cover it
Sent from my GT-I9100P using Tapatalk
X5 E70 3.0D SE
pcdee
Post by pcdee » Sat Jun 14, 2014 12:59 pm
Just as I thought no cover.
I will book with my indy see what the costs....might just get the parts online only £200 for both sides
X5 E70 3.0D SE
