brake judder
w77thy
brake judder
Post by w77thy » Tue Jun 03, 2014 7:49 pm
Hi Some help needed please, I have an e53 3.0d 2005 , changed disc and pads the other week , I have brake judder through steering wheel at speeds between 60-80 mph, please can anyone shed some light? Thanks
Re: brake judder
Post by X5Sport » Tue Jun 03, 2014 8:26 pm
Who's pads and discs did you use?
Might be contamination?  Is everything looking OK in terms of the pads nicely settled against the discs?  Or even perhaps the mating surfaces between the disc and hub having something on them causing one disc to sit unevenly on the hub?
Doesn't need much to shift the disc a fraction.
bigsanj
Re: brake judder
Post by bigsanj » Wed Jun 04, 2014 8:54 am
Could you of disturbed the caliper causing it to start seizing?
PhilT
Re: brake judder
Post by PhilT » Thu Jun 05, 2014 9:32 am
If you're feeling it thought the steering wheel it's more likely to be worn thrust arm / wishbone bushes rather than brakes. Lots of us have been fooled by that one - do a quick search, there's plenty of advice.
Hth
Phil.
Current Drive:
E71 X6 30D 2011
E53 X5 3.0D 2004
Previous:
S54 Z3 MCoupe 2002
S50 Z3 MCoupe 1998
E46 330 Ci Sport 2003
