Towing Buzzer
7builder
Towing Buzzer
Post by 7builder » Sat May 10, 2014 4:23 pm
I hitched the caravan to the X5 today for the first time to check the electrics were working ok. All the lights on the back of the caravan work as they should so no problem there but the indicator buzzer located in the rear of the car somewhere seems to have a mind of its own.
When I indicate left or right I get a continuous beep beep noise as I have done with every other tow vehicle I've owned. If I barake when indicating I get a continuous Beeeeeeeeeeeeeeeep until I come off of the brake pedal. When I switch the lights on there is a long beep for about 3 seconds before it stops. However if I hit the brake pedal when the side/main lights are on I get a continuous beep for as long as I am braking.
The towbar is a cheap looking aftermarket fixed jobbie that juts out from a cut out in the rear bumper with standard 7-pin electrics and I am wondering if it has been installed correctly or professionally. Does the symphony of buzzing noises sound correct or should I only hear a noise when indicating?
Re: Towing Buzzer
Post by X5Sport » Sat May 10, 2014 4:28 pm
Sounds like an after market job as the correctly fitted OEM ones are silent.  It might be the PDC has been left active or the wrong wires used inside the car.
The decent OEM kits have a module that just plugs in to the pre-fitted socket in the boot which, once a trailer is fitted, turns off the rear PDC, adapts the lighting and modified the DSC system taking the trailer into account.
7builder
Re: Towing Buzzer
Post by 7builder » Sat May 10, 2014 4:39 pm
Thanks Richard I hope the wiring wasn't messed with too much. I guess I'll have to trace it back from the tow hitch and see what I find. Lets hope it can be reverted back to standard and the correct module fitted.
