De-Badge your X
How-To articles go here.
TonyX5
De-Badge your X
Post by TonyX5 » Mon Apr 28, 2014 9:25 pm
I am not a fan of badges on cars, so my first job is to de-badge them
The first thing to do is heat up the glue that holds the badges on, you can use a normal hair dryer.
You then need to cut through the soft glue using something like dental floss or fishing line, just use a slow sawing motion.
When the badges have been removed there will probably be some glue left on the car, most of this can be removed by rubbing off with your finger any glue remaining can be removed with something like Tardis.
When all the glue has been removed you will probably still see an outline of the original badge, this can be polished out with something like Meg's 105 or T-Cut.
You are then left with a car with nice clean lines.
Tony
Re: De-Badge your X
Post by X5Sport » Mon Apr 28, 2014 9:31 pm
Nice write up.  :ok:
I used isopropyl alcohol (don't use it neat though!) to remove the glue, and white spirit does the job pretty well too.
TonyX5
Re: De-Badge your X
Post by TonyX5 » Tue Apr 29, 2014 8:54 am
Thanks Richard and thanks for the additions.
goose
Re: De-Badge your X
Post by goose » Fri May 30, 2014 10:22 am
Ditto, also the very first thing i did on mine..  the day i got it home!
I see you also switched the rear BMW badge from blue to black too..  was that a simple job?
Cheers,
goose
_______
2008 X5 3.0sd M Sport - Carbon Black - Evolution remap
1972 VW Karmann Ghia Coupe - Sunburst Yellow
TonyX5
Re: De-Badge your X
Post by TonyX5 » Sun Jun 08, 2014 4:43 pm
Sorry goose for the delay, I have only just seen your question.
The rear badge was quite fiddly, the badge is a complete unit with the actual bmw logo part of the badge is on very thin metal.
To remove this part of the badge you can either heat the glue up and prise the middle out or I cut a 25mm hole in the centre of the badge and removed it that way.
I then filed the plastic part of the badge where the original logo was down as fine as I dare using a Dremel.  The only replacement badge I could find was the same as the front one, so I first cut te two lugs off then filed the new badge down as fine as I could I then stuck the new badge to the plastic where the old badge was.
The new badge sticks out a couple of mm but I can live with that.
I also replaced the bonnet badge and the wheel centres
Hope this helps
Tony
centurion
Re: De-Badge your X
Post by centurion » Tue Oct 28, 2014 11:32 am
nice job... cannot wait to get my hands dirty hopefully soon :).
pvr
Re: De-Badge your X
Post by pvr » Tue Oct 28, 2014 11:47 am
Just debadged my Audi as well, no need for the wire though - just used my nails around the corner to pull it off but it does hurt with the hairdryer on it ...  :blink:
But being a former Z4M driver, I am in touch with my nails and hair dryers  :))
Before:
After:
And a nice upgrade to a Turbo for my 911  :))
Re: De-Badge your X
Post by X5Sport » Tue Oct 28, 2014 12:26 pm
The Audi is still embarrassing whether badged or not....
I thought the 'T' marked the tow point?
splang
Re: De-Badge your X
Post by splang » Fri Apr 10, 2015 8:22 pm
thanks for the info. I just debadged my 40d including the 40d parts (stealth power!).
