x5 manual gearbox help
610kev
Post by 610kev » Wed Apr 23, 2014 7:27 pm
hi I need some help advice please  .  I was driving at about 10mph in 2nd gear and all of a sudden then car lurched forward and stopped as if all the brakes where on and would not move forward . I put it into neutral and the car free wheeled no problem , went into 1st 2nd and it locked up again with a really bad noise .drove it onto drive and noticed I what I think is gearbox oil dripping onto
the floor . any ideas please    manual  diesel 55 plate
RoShamBo
Re: x5 manual gearbox help
Post by RoShamBo » Wed Apr 23, 2014 8:18 pm
Gearbox ?
610kev
Post by 610kev » Wed Apr 23, 2014 8:21 pm
you saying it is the gearbox
Post by X5Sport » Thu Apr 24, 2014 7:48 am
Sounds like transmission so could be gearbox, transfer box/xDrive unit - the ATC500.  You'll need to get underneath to establish exactly which as you need to be able to detect where the oil is coming from.
With the car stationery and switched off, can you select all 6 gears?  If you can then it's less likely to be the box itself and they are a very rare failure whereas the transfer case/xDrive units are more likely especially given the car stops.  Will it move in any other gear, or is it just 2nd that has the issue?
This is the transfer unit/xDrive unit
610kev
Post by 610kev » Sat Apr 26, 2014 12:27 pm
hi got the x5 on a ramp and its the diff ,its got a crack in it . right i need to know how to find what ratio the diff is  any ideas thanks kev
Post by X5Sport » Sat Apr 26, 2014 12:36 pm
Which diff?  Front or rear?
610kev
Post by 610kev » Sat Apr 26, 2014 4:42 pm
sorry its the front diff  so I will need one any ideas where to get one apart from ebay thanks kev
Post by X5Sport » Sat Apr 26, 2014 5:04 pm
A breakers might be your best bet, apart from getting a new mortgage with BMW of course  :(
These guys seem to be on various boards, bmautoparts, but I have no experience of them.
