Is the 3.0sd engine, gearbox same as LCI e60 535d?
celica
Is the 3.0sd engine, gearbox same as LCI e60 535d from 2007+
martin33100
Re: Is the 3.0sd engine, gearbox same as LCI e60 535d?
[quote="celica"]
[/quote]Engine should be the same but the sump is different as it holds the front diff on the X5, also the X5 gearbox may be different as its set up to drive a transfer box and not just a rear axle like the e60.
