No sat nav voice but everything else okay
alz4m
Post by alz4m » Sun Mar 30, 2014 9:53 pm
Hi there- bit of a newb to X5s but I've done some research and can't find an answer to my problem.
Basically the nav works as does the radio, cd and cassette(!) but I don't get any voice instructions. I've checked that instructions are switched on and turned the volume up as high as it will go but I get absolutely zilch- the music source turns off to allow the instruction to come through but I get nothing other than silence!
I've tried all the menu options and even upgraded the firmware in the hope of it fixing it but no joy... Any ideas?
It's a mk3 nav btw with small screen.
Re: No sat nav voice but everything else okay
Post by X5Sport » Sun Mar 30, 2014 9:56 pm
Genuine disc in use?
alz4m
Post by alz4m » Sun Mar 30, 2014 10:19 pm
Yes- although it's the original so seems a little beat up but no read issues.  I thought it might be worth actually copying the cd to a new one in case it was the scratched cd causing problems- that said the voice isn't intermittent or stuttering, it just doesn't work!
Mpower
Post by Mpower » Sun Mar 30, 2014 10:27 pm
There's an info button on the there press it to remove the "I" on the screen,try it hope it helps.
pvr
Post by pvr » Sun Mar 30, 2014 10:38 pm
Does the test voice work in settings?
alz4m
Post by alz4m » Sun Mar 30, 2014 10:55 pm
When you change the volume? No. I assume when you change the volume the voice usually says 'louder' / 'quieter' but mine is mute.
The voice control still talks but just no nav directions.
Thanks for your assistance so far chaps.
Sim0x
Contact:
Post by Sim0x » Mon Mar 31, 2014 5:44 am
Your correct, when you change it in settings it normally says: "Quieter" & "Louder".
alz4m
Post by alz4m » Thu Apr 03, 2014 11:10 pm
Thanks. It seems like my head unit doesn't have an info button- I'm pretty familiar with bmws so I can only assume something is disconnected/broken but if that's my only real problem (other than my dodgy passenger mirror) then I'm pretty content!
Mpower
Post by Mpower » Sun Apr 06, 2014 7:48 am
Found this from another site regards to same problem you're having;
"Before I had a chance to re-visit the forum I had one more quick 'play' with it to see if I could fix it.  I tuned into a MW radio station then started pressing the buttons, when I pressed 'Info' the 'I' vanished off the screen and the sound came back to life! "
alz4m
Post by alz4m » Sat Apr 12, 2014 6:56 pm
Thanks for all the pointers- unfortunately none seem to work!!
I've checked all the wiring and actually changed the sat nav to a widescreen unit today but still no voice directions. However, I have a theory- my car is equipped with a long defunct Traffic Master unit and when activated it has a Red Cross on the screen over a red box and I think that might be the problem but I can't see how to click on that box... Any ideas?
I think that it's the mute for the tm and it's also muting the directions but using the single rotary control for the tm I can't find any options re un muting it.
