Hi All
ran a check using my new V1.4 scanner(direct from the factory (1 week delivery) and found a couple of errors;
VTG* 54c6/61 - OIL Abrasion on the transfer box
and
DME* 28D6/68 - HO-Prooc. failure, coding missing
and
LEW 09/B3 - No Can Message
        04/19 - 90 degree difference of wiper too large (adjustment operation)
Now the first one I take it o be requiring new oil in the transfer box?
Is the second one a new Lambda sensor?
any ideas?
Darren
X5 4.8is Le Mans Blue 2004
	Found errors using scanner
- dwgwyther
Soon very soon to be  X5 40d
Previous - X5 2004 Le Mans Blue 4.8is
				chas3
Re: Found errors using scanner
54C6 requires the change of.. well.. the lifetime oil in your transfer case. The DIS service plan of reseting the adaptation values will have to be conducted after that, in order to clear the error.
I have no idea about the other 2, maybe you could post the INPA dump.
