Wing mirror motor needed, just the individual motor.
Posted: Mon Mar 17, 2014 11:49 pm
by stu21t
My passenger wing mirror has lost it's left/right movement, I have stripped it all down and found it's the individual motor.
Anyone know where I could get one?
All places sell the actuator unit complete.
I have found one very similar from maplins but I obviously don't know the specs of the std motor.
Or anyone got a broken mirror I can buy?
Re: Wing mirror motor needed, just the individual motor.
Posted: Tue Mar 18, 2014 7:23 pm
by JimmySpeed
Can I ask how you got the mirror glass off. Mine feels like it will break if I pull any harder.
I have the same problem as you except I have no up/down movement.
Sent from my SM-N9005 using Tapatalk
Posted: Wed Mar 19, 2014 12:29 am
by stu21t
If you pus the right hand side in as much as poss then pull the left side out gently you should be able to see behind the glass, there is a plastic circle with tabs on it holding it on, you need an angled pick to get behind and release the tabs, you need to release about 3 of them and the glass will left away.
Be very careful lol.
Mine had actually stopped moving up/down and I swapped the motors over so it did move up/down and not left/right. It's more important for me to see the kerb than adjust in/out. Once the left/right position is set you don't need to move it really.
Posted: Wed Mar 19, 2014 6:31 am
by JimmySpeed
Thanks for the reply.
I was actually planning on swapping my left up/down motor with my right up/down motor until I find a new motor like you (watching this thread with interest!!!) but what you say is correct - once its set left/right it doesn't really change unless someone else drives the car (and I don't let anyone drive my cars!)
Posted: Wed Mar 19, 2014 9:32 am
by stu21t
Swapping the motors is easy
Pop the glass off, then the round backing plate, push a flat screwdriver into the square holes with arrows on them to release it off the moving arms
Then you need a T10 torq bit and there's 4 screws holding the motor on,
then remove the rubber cover, there's another 4 T10s under it (2 in the middle 2 by the arms)
Then lever the 2 1/2s of the case apart pulling the tabs out the way.
Now you should have the actuator unit apart and see the moving internals.
Pull out the red circuit board carefully (there 4 pins on the back) rest it over, then prise the black plastic bit off the motors, again there's 4 pins in the middle and 2 pins on each end that go into the motors so don't bend it.
Swap the motors then refit.
Should take you about 1/2hr.
This is who make our actuators
http://www.magna.com/about-magna
I've emailed them to see if I can buy a motor.
I've found plenty on the net that are the same size but none have the 2 pin power input like ours so might not work.
I will let you know how I get on.
Posted: Wed Mar 19, 2014 10:21 am
by JimmySpeed
Cheers. That's on my list today actually!
Hopefully the motor hunt proves fruitful
Posted: Wed Mar 19, 2014 7:49 pm
by JimmySpeed
Thanks for the excellent walkthrough.
Following your guide I did the motor swap with ease today. I finally have dip reverse.
It's really the only function that I require to be electric as none of the other positions ever change in my car.
Posted: Wed Mar 19, 2014 7:56 pm
by stu21t
No probs, so yours and mine have exactly the same prob.
I was unhappy my car didn't have dip reverse, now it does.
No reply from magma yet.
Posted: Wed Mar 19, 2014 8:24 pm
by JimmySpeed
I rarely use the dip but on the odd occasion that I need to it's invaluable
Posted: Wed Mar 19, 2014 8:36 pm
by Nine468
Wow. Just what I was after, a how to on replacing the up down movement on the passenger side wing mirror..
. Yes mines failed aswell...
