Water leak going to webasto.
sunnybono
Post by sunnybono » Sat Mar 15, 2014 5:17 pm
Hi,
Noticed some coolant on the drive the last couple days and I think I have traced it down to the pipe union joint that comes from the head (assume it is as under the engine cover) and goes into the webasto unit.
Not having much luck finding the diagram on realoem either but thought I would check if this was common.
sunnybono
Re: Water leak going to webasto.
Post by sunnybono » Sun Mar 16, 2014 10:15 am
I believe it is number 19 on this image
