Tyre load rating help
ArthurSleep
Post by ArthurSleep » Thu Mar 06, 2014 12:12 pm
Hi gents, can anyone help me out with a tyre pad rating question?
I need to replace both front tyres on my 3.0d.
Currently on there is some Achilles Desert Hawk 255/50/R19 107V
Looking to add some Toyo Proxies to match the ones recently fitted on the rear. Which are 285/45/R19 107V
The ones I've found (one new / one 7mm tread nearly new) I can get for £100 all in delivered.
They are 103V rating.
I've checked the inner door label but want to make sure I've got the correct info.
Any issues to having 107V tyres on the rear & (same brand) 103V tyres on the front?
Re: Tyre load rating help
Post by X5Sport » Thu Mar 06, 2014 12:39 pm
If the rating plate says 107 on the car then you must not go below it.  You can go higher, but not lower.
The difference in this case is 100kgs less load capacity per tyre at 103 - or 200kgs across the front axle.
To use under-rated tyres could invalidate your insurance.
ArthurSleep
Post by ArthurSleep » Thu Mar 06, 2014 1:13 pm
Thanks Richard.
Rating plate from the inside door is as below. Two pics showing left side & right side.
It mentions 255/50/R19 103V on the first pic there. So will they be legal on the front? with 107V rated Proxies o the rear?
fenj66
Post by fenj66 » Thu Mar 06, 2014 1:59 pm
mine are 103 on fronts and 107 on rears. so sounds normal...
Sanj
Post by Sanj » Thu Mar 06, 2014 2:06 pm
This is mine on Toyo Proxies but 20s - 106W:
Dan1502
Post by Dan1502 » Thu Mar 06, 2014 2:38 pm
103 is fine for the front.  That's what the Michelin Diamaris fitted at the factory are.
2004 E53 3.0D Sport
2016 F25 X5 35D MSport
Post by X5Sport » Thu Mar 06, 2014 3:13 pm
They're fine as said by the rest above.
R
