2004 3.0D Sport - smoke on cold start
X5_NZ
Post by X5_NZ » Wed Feb 05, 2014 9:19 pm
I have noticed that on cold starts (usually 1st thing in the morning) there is a bit of blue smoke from the exhaust.
This does clear up after a couple of seconds and won't happen again unless the car is not driven for a few hours.
I have had it plugged in and this has been diagnosed as all 6 glow plugs??
I have read that the control unit for these Is the usual suspect but how could I check this?
Thanks in advance  :)
Sanj
Re: 2004 3.0D Sport - smoke on cold start
Post by Sanj » Wed Feb 05, 2014 9:27 pm
Blue smoke on start up is normal on these cars. Mine does it.
Post by X5Sport » Wed Feb 05, 2014 9:39 pm
As the man says, completely normal on a diesel cold start.
Can't be much wrong with the glow plugs either unless you need some serious cranking to get it to fire.....?
X5_NZ
Post by X5_NZ » Thu Feb 06, 2014 10:07 am
it fires up perfectly fine all the time but it was just the blue smoke I was concerned about!
I may just end up leaving it if it's a normal thing  :)
I have had a 530d and a 535d and they were completely smoke free!
Denis O
Post by Denis O » Thu Feb 06, 2014 11:28 am
As Sanj and Richard have said, it is completely normal but, doesn't always happen.
My 04 car did it as soon as the weather turned cold. My 06 car has never done it. Same engine and fuel/ignition system to all intents and purposes but totally different in this respect.
My 535 didn't do it either but then I guess that's a little different to the e53 facelift.
05 Mercedes SL350
Sanj
Post by Sanj » Thu Feb 06, 2014 11:31 am
Think the 5 series don't do it because of the DPF. Also think Richard mention the X5 diesels run a little rich on start-up?
Denis O
Post by Denis O » Thu Feb 06, 2014 12:12 pm
[quote="Sanj"]
Good lord Sanj. You've found a useful purpose for a DPF. Well done  :)
05 Mercedes SL350
fenj66
Post by fenj66 » Thu Feb 06, 2014 12:59 pm
mine has done it every morning last 5 years, no issues, no high oil consumption, 3 glow plugs showing faulty, car starts and fires first turn of the key no broblems.
my old 330d does not do it even at 200k miles! im sure its nothing to worry about..
Sanj
Post by Sanj » Thu Feb 06, 2014 2:07 pm
[quote="Denis O"]
Why is the DPF hated so much?
X5_NZ
Post by X5_NZ » Thu Feb 06, 2014 5:54 pm
Thanks for the replies  :)
If it stays the same I will just leave it!
I think the DPF is just hated purely because of the horror stories about replacement costs people hear when it goes wrong! My previous Leon FR TDI had a replacement fitted at a cost of £2100!!
Sanj
Post by Sanj » Thu Feb 06, 2014 6:43 pm
In that case, I hate it already!
X5_NZ
Post by X5_NZ » Thu Feb 06, 2014 8:12 pm
[quote="Sanj"]
Ha Ha Ha Ha!!!!!  :)) :)) :))
Post by X5Sport » Thu Feb 06, 2014 10:04 pm
Well it was an Audi part, so waaaaay overpriced......
(Now hoping that doesn't but the kibosh on the X6 one.. :(. )
