Rotational Vibration under load - Any Help Appreciated
Well, where do I start.
Had the driveshafts replaced September last year and after a few weeks started getting this rotational vibration. Very light at low speeds but increases somewhat at higher speeds. The vibration can be felt through the floor at the front and in the steering wheel too tbh.
If cruising at 70 say and you take foot off the accelerator it dies down considerable too.
I've had the driveshafts replaced as they were covered by warranty as obviously that was the first port of call. Then the second set have been replaced yet again but with OE quality parts as the one popped out the diff (not good really).
Now with decent driveshafts in I've still got this really annoying vibration and I've had a few people look at it to try and work out.
We've discount the suspension and all the bushes at the front. Also the brakes, balancing and driveshafts.
Remaining possible causes are diff, transfer box, gearbox, propshaft, etc.
And as you can see the possible causes are all bloody expensive to replace on the hope it will cure it.
Any ideas???????
Any ideas???????
- stevox5
Re: Rotational Vibration under load - Any Help Appreciated
Hi Raj
Did this occur since you changed to different rims or was it the same with your previous wheels?
Any chance you have a brake binding slightly?
Any other symptoms ?
[quote="stevox5"]
Hi Raj
Hi Steve,
Rims were on before so it's not that. I even tried the Alpina's and was still the same.
Brakes appear to be all ok as again we have checked them too.
That's kind of all the symptoms tbh.
Well actually you can feel it change when going over bumps etc too…hmmmm.
I was wondering if wheel bearings would do this but again all the mechs that have seen it have said no...
Cheers,
Raj.
Hi Raj
Hi Steve,
Cheers,
Raj.
Engine Mounts OK? Gearbox mounts? Not sure if they are flexible but the power on/off difference just made me think of items that would change loading with throttle
Just trying to think of anything you haven't. Was going to suggest wheels out of true - even if balanced - but that should show up whether power on or off. Any tyre issues?
I would have thought the prop shaft balance etc would still be felt as long as it was rotating power setting independent, but I've been wrong before.
Never anthropomorphise computers. They hate that.- shadrack
Propshaft donut? Can split and get progressively worse
current: 2016 Vw Crafter
Hi Richard,
I took the X over to Chris @ Centre Gravity as he's a real expert at geo/suspension/etc and he tested the suspension on some very clever equipment he has. Also checked engine mounts etc too and all seems ok.
Hi Richard,
[quote="shadrack"]
Have looked at those and again they actually look pretty good with no signs of real wear/cracks etc.
Oh and it appears I have a very, very small leak from the pan gasket on the bottom of the gearbox.....great.
Have you tried turning down those subs of yours? :music: Could be sympathetic harmonic vibrations from Bangra?
Only kidding.....
What about loose engine/underbody shields? Used to see Sierras and Mondeos going along with plastic flapping so just wondering if one of the covers underneath has lost a clip?
Can't be much else left - except a 'square' wheel.
Only kidding.....
Lol Rich.
Tbh undertrays all fine etc.
If it's not wheel bearings then I'm starting to think front diff. But at £1100 odd plus fitting its a big hit without knowing if it will cure it.
I'm thinking with the fact I have a small gearbox leak and having 120k on the clock I might need to get a full gearbox rebuild done (£1600 odd too). My thinking with that is its gonna cost me a fair bit just get the oil changed with new gasket and whatever else and then if the stories are true the new thin oil could actually cause further gearbox issues meaning it'll need doing anyway. So suddenly looking at £3k+ aghhhh
- shadrack
Ive done donuts on a few bmws now not x5s but the crack can be very hard to spot without removal. Is it possible to get strapped on a rolling road or similar so you vould run it at vibration speed and look/ listen at same time? Just before you start throwing £££s at the big stuff
holidaychicken
hi all, i am a filthy range rover owner but have been getting some help off a few of your members, Richard included, as i think i am right in saying the RR and the X5 are the same underneath, mine is the 4.4 petrol.
it might be worth googling the L322 for the same problem as it could be the donut as you say, the RR's all have had a front diff recall to add a flexible joint in at the front to stop the diff splines failing i think but all sorts of other problems can cause this on rr's from mud on the prop shafts, suspension bushes, warped brake discs and sticking calipers, over size wheels, and also out of balance wheels, as this seems to be common, but probably not in your case if you have tried another set.
i also rebuilt the transmission, with a lot of help, which again i think will be the ZF units, if yours is a 4.4, or GM for the tractors, i mean diesel, as i also had a small oil leak but i had the annoying torque converter lock up clutch rumble as well but thats at slower speeds than 55.
i think if its not wheels then my money would be on the donut, especially if its worse under load
- crash
Raj,
Will be following this with interest as i seem to be suffering the exact same issues as yourself!
I have noticed that the noise increases further going uphill as well as when accelerating, yet as you have mentioned backs off to almost non existent when you lift off the throttle!
After replacing bushes, ball joints, one wheel bearing, full set of star rated tyres and a full alignment i am now on to the flexi joint for the next in line for replacement.
Not had a look under there yet but i assume the X5 has some sort of central support bearing that could also be the issue!
Ash
Ash
Donut on both forward and rear props and yes the rear has a support bearing.
3.0D diagram as an example. 4.8is is the same.
Never anthropomorphise computers. They hate that.- crash
Thanks Richard,
Forgot to mention mine is a 3.0D so that diagram is more than helpful
Will have to find somewhere to get the parts and get them changed next week.
Regards
Ash
Regards
Ash
