x5 issues
gareth08
x5 issues
Post by gareth08 » Sun Jan 12, 2014 5:04 pm
Hi..have just aquired a x5 which I believe you refer to as an E53. Its a 11/05 registered car but a facelift version and is a 3.0d le mans sport exclusive.
I have the following issues which I hope you can help me with.
1. I can't get my galaxy s3 lte to pair with the x5....can get as far as bluetooth pairing but when I try to discover the x5 I nothing happens...phone is ok as it pairsok with my other car..
2. I keep getting message on dashboard display saying ' check parking lights ' any ideas why this is coming up and why.
I'm sure I'll hava a load of other questions soon :)
Gareth
briankerrys47
Re: x5 issues
Post by briankerrys47 » Sun Jan 12, 2014 11:31 pm
[quote="gareth08"]
Gareth
[/quote]1 clear memory on car,2 check light!!! If working check state of Battery? 2simple checks but 'Richard' will come up with more comprensive answers And welcome
Re: x5 issues
Post by X5Sport » Mon Jan 13, 2014 10:28 am
Bluetooth......as above.  Too many existing pairings may be the problem.  I think it only allows four, so you need to clear any old ones first.
The parking lights sounds like one of your sidelights (front or rear) is out.  The car checks all bulbs with a short pulse to see if the filaments are OK.  If the previous owner fitted LED lights then you need a resistor in circuit to cancel the errors.
ChrisLux
Re: x5 issues
Post by ChrisLux » Mon Jan 13, 2014 12:20 pm
[quote="gareth08"]
I've had that with mine , and cud be bulb failure , but it's easy to tell because normally the 'Halo' side lights
are the Park Light , if the bulb has gone then the indicator bulb lights up instead .
Steamyrotter
Re: x5 issues
Post by Steamyrotter » Mon Jan 13, 2014 1:27 pm
[quote="ChrisLux"]
[quote="gareth08"]
You can also get this from a high resistance joint on the plugs to the rear clusters.
Lights work but error comes up.
Check Bulbs, holders and plugs / connections.
