Runflat Problem
Bob1098R
Runflat Problem
Post by Bob1098R » Wed Jan 01, 2014 6:17 pm
First of all Happy new year guys,
I hope the hangovers have subsided  :)
I got a runflat warning last night for the passenger rear ,
I connected my digital compressor to take a pressure reading but i'm not getting any air through the valve ,
I checked the operation manually pushing the pin in the valve but still nothing would come out,
Is their a problem with the valve or is this a characteristic of runflats with a puncture ???,
The tyre looks and feels ok but i cant say for sure what pressure its holding,
Thanks and all the best,
Bob.
Current-F15-40DM & Ducati 1098R Track Bike, Monster 1200S, KTM 450         Previous-
BMW        E70 3.0sDMport
Audi         A6 3.0 Allroad    Ducati1198S
Porsche    Cayenne 4.5 S    Ducati 1098S Tricolore
Mercedes  C Class 2.0S       Ducati 999 ZX6R Ninja
Re: Runflat Problem
Post by Horizon » Wed Jan 01, 2014 6:31 pm
If the gauge is showing the correct pressure you should have that pressure in the tyre. Maybe check it again at a garage, but usually depressing the pin in the valve should release a bit of air.
Bob1098R
Re: Runflat Problem
Post by Bob1098R » Wed Jan 01, 2014 7:12 pm
[quote="Horizon"]
Thanks for the reply, problem is the valve is not letting any air in or out (perhaps it's blocked) so i cant get a reading on the display ,its a good gauge and i tested it on the other wheels to make sure it was working correctly,
The tyre has loads of tread , i hope it wont be a change out  :(
BMW        E70 3.0sDMport
Finglonga
Re: Runflat Problem
Post by Finglonga » Wed Jan 01, 2014 7:43 pm
Have you tried removing the valve core?
Re: Runflat Problem
Post by X5Sport » Wed Jan 01, 2014 7:48 pm
A lot of places will repair a run flat for you with little or no comment depending upon where the sharp went in.
It could of course be that the valve is actually the issue.....are all the other valves OK?  Just thinking if some 'wag' has applied superglue.... >:(  :rant: .....as a poor (and dangerous) prank..
Bob1098R
Re: Runflat Problem
Post by Bob1098R » Wed Jan 01, 2014 7:50 pm
[quote="Finglonga"]
I want aware that could be done,
Is it an easy job ?
BMW        E70 3.0sDMport
Bob1098R
Re: Runflat Problem
Post by Bob1098R » Wed Jan 01, 2014 7:54 pm
All the other valves were fine Richard,
I had a good look at the valve and it doesn't look like anythings been tampered with ,
I think you have answered my next question though, i dont need to take it to BMW for repair or replacement ? , i take it any tyre fitter will repair or supply a run flat ,
Thanks.
BMW        E70 3.0sDMport
Re: Runflat Problem
Post by X5Sport » Wed Jan 01, 2014 8:21 pm
Local tyre place did mine... :)
It's on a standard rim.  BMW may well say it can't be done, but mine was done 12,000 miles ago and is fine.
The valve cores unscrew. Halfrauds do a tool to do the job.
Pope
Re: Runflat Problem
Post by Pope » Wed Jan 01, 2014 8:54 pm
I had quite a large hole in one of my rear RFT's. Local Tyre Fitter (Tyres Direct) plugged the tyre, and its been perfect now for more than 6 months.
Why throw £300 away buying a new tyre, when you can get it safely repaired for £10.
:pope:
Garage:
BMW X6 40d Pink
Ducati Diavel 1198 Carbon
Bob1098R
Re: Runflat Problem
Post by Bob1098R » Wed Jan 01, 2014 10:28 pm
[quote="Pope"]
Sounds like a plan,
I'll make a few calls in the morning and see what I can get locally,
BMW        E70 3.0sDMport
