Page 1 of 2
Television Not working
Posted: Wed Dec 25, 2013 11:47 am
by aneeque27
Hi,
I recently bought X5 3.0D(2006) but the television is not working. I have tried rescanning all channels but still didn't worked. Although it shows all channels there but no audio and visuals. Can you please help.
thnx
Re: Television Not working
Posted: Thu Dec 26, 2013 1:36 pm
by Woofer
I've the same issue, it is analogue and the system has switched to digital, you'll need to change the whole unit for aftermarket AFAIK
...or wait until u get home to watch TV
Posted: Thu Dec 26, 2013 2:02 pm
Interesting. A 2006 should have a dual unit as they were fitted from late 2004 onwards. If you have an analogue only in yours then it's either been replaced with a different unit or that part of the receiver has failed.
All sounds a bit suspicious to me.
Posted: Fri Dec 27, 2013 11:49 am
by CondorX5
As Richard said above, the TVs from 2004 onwards were hybrid receivers so both analogue and digital signals received......i had a late 2003 3.0i a few years back which was an early facelift and even it had a hybrid tv receiver, so either you are simply not in a good reception area or the original hybrid receiver from your car was swopped out by its previous owner.........
Posted: Sun Dec 29, 2013 4:10 pm
by aneeque27
Sorry for late reply. Yes it does have a dual unit because when i rescan channels, it does say the Analouge channels found and digital channel found. But it could be that i m in a bad reception area.. Will try scanning some other place. cheers!
Posted: Sun Dec 29, 2013 4:54 pm
by Sanj
Check the antenna is connected after that, both ends (at the unit end and in the windows - rear most quarter panels).
Posted: Sun Dec 29, 2013 9:12 pm
by Drpellypo
Mine is 2004 and only appears to be analogue. How can you tell?
Posted: Sun Dec 29, 2013 9:50 pm
Dual mode (hybrid) receivers were officially installed from production starting after 1st October 2004 - around Week 40 for that calendar year if memory serves. If it was made before then then it is likely you won't have one unless the original unit was replaced under warranty. After that date they should all be dual mode.
I think the TV module is down by the battery? See if you can find a part number on yours.
Posted: Sun Dec 29, 2013 11:24 pm
by Woofer
I'm now wondering whether I can get a dual mode OE replacement for my analogue receiver, any one got any clues as to where/how much?
Posted: Mon Dec 30, 2013 10:11 am
by aneeque27
hi,
Its working now, i think i was in a bad reception area.
Thanks for your help guys :xmaswink:
Posted: Mon Dec 30, 2013 10:50 am
[quote="Woofer"]
Should be a straight replacement. Have a look on ebay etc. Dealers can also supply, but the price is stupidly high - like several hundred pounds!!
If you do get one from ebay, make sure it is a proper dual mode unit and is for the UK TV spec (PAL/DVB-T) and not NTSC (US Spec).
Posted: Mon Dec 30, 2013 11:30 am
by Woofer
[quote="Woofer"]
Cheers Richard, I'll go look
Posted: Mon Dec 30, 2013 4:54 pm
by Drpellypo
Ah mine was March 2004. Bummer!
by Drpellypo
Thanks for the info
Posted: Fri Jan 10, 2014 5:13 pm
by Smeeagain
I have the September (!) 2004 analugie model - Id like to tackle this job but unsure as to the correct item - would someone mind posting what the correct item is on ebay as I ma unsure - at my risk if I make the purchase etc
