vibration through s/wheel under breaking
On my X5 2004 E53 3.0d sport I am getting a vibration through the steering wheeel when braking moderately (ie its not ahrsh brakign witht he abs kickign in) - as the car starts to slow down the vibration goes away
Wheel balance I'm thinking?
smee
smee
Re: vibration through s/wheel under breaking
Hi, It could be your tension arm bushes.Number 7 in the link.
http://www.realoem.com/bmw/showparts.do ... g=31&fg=05
or warped discs ?
ok thans
The car was mot'd a month ago and discs were advisory as being slightly worn. All else was fine then. The vibration was happenning before the MOT to eb honest That aside how do i go about getting bushes or discs checked. Would it be cheaper for me to start by having the wheels balanced and see what that does (and of course does no harm to have the wheels balanced anyway)?
Smee
Smee
if the wheels need balancing, it would cause a vibration whilst driving, not while braking, vibration when braking will almost definately be warped brake discs in my experience
Do a quick search and you'll find lots of info on here about this problem, my money is on item 10 or maybe item 7 (or even both) on the realoem diagram and not warped discs.
Phil.
Current Drive:
E71 X6 30D 2011
E53 X5 3.0D 2004
Previous:
S54 Z3 MCoupe 2002
S50 Z3 MCoupe 1998
E46 330 Ci Sport 2003
Phil.
Current Drive:
E71 X6 30D 2011
E53 X5 3.0D 2004
Previous:
S54 Z3 MCoupe 2002
S50 Z3 MCoupe 1998
To check item 10 for wear - jack car up at front when font wheel is off the ground try rocking the wheel at the bottom if there is movement the bush of item 10 is worn were it bolts onto the chassis.
item 7 not very easy to tell if worn, these are the oil filled bushes.
My car vibrated under breaking, changed both parts at the same time. (item 7 now poly bushes - downside suspension harder, upside should never have to change again).
Phill
Phill
2003 X5 4.6is - Now dead
- jason@bwchiptune
- Contact:
if your near hounslow middlesex pop over and i will have a look for you
TUNING DEALERS ACROSS THE UK
DYNO DYNAMICS ROLLING ROAD
http://www.bwchiptune.co.uk
02085611818
02085611818
thanks - I'm in Hampshire but can be in Hounslow - give me a bit of time and I'll get it over to you
Smee
Smee
