				Phone
				Posted: Fri Dec 20, 2013 6:53 pm
				by Callum89
				Hello all,
This will sound stupid but I have never done this before can I connect my I phone to my car for phone calls music etc, I have had a look through the book and pressed buttons but I haven't got a clue what I'm
Looking for or doing
Cheers guys
				Re: Phone
				Posted: Fri Dec 20, 2013 7:06 pm
				Which model/year of the X do you have?
				Re: Phone
				Posted: Fri Dec 20, 2013 7:37 pm
				by Callum89
				2005 3.0i sport
				Re: Phone
				Posted: Fri Dec 20, 2013 8:00 pm
				Music will need a separate connection as the OEM Bluetooth is only V1.1 which doesn't support it.
The phone should work via Bluetooth but you may need to delete all existing pairings before you can pair your own phone to the car (it only allows 4 pairings before refusing more).
Note that not all phones work properly and certain functions are not available at all depending upon phone model.
You should have a book for it in the car, plus the car's PIN.
				Re: Phone
				Posted: Fri Dec 20, 2013 8:17 pm
				by Callum89
				I have flicked through the book but haven't seen anything to help me I'm
Assuming its got Bluetooth as I have the phone buttons on dash/steering wheel
				Re: Phone
				Posted: Fri Dec 20, 2013 9:04 pm
				Have a look at this
thread to see if it helps.  Replies 11 & 13 may help as well.
I assume you have all the right manuals including the Bluetooth one?  You also need the 4-digit Bluetooth PIN for the car....do you have that?  I think the pairing button is in the armrest area (?).
It is possible the BT module is down or has been removed.  It should be in the left rear cubby if memory serves, and mounted at an angle at the bottom of the cubby.
				Re: Phone
				Posted: Fri Dec 20, 2013 9:31 pm
				by Callum89
				Ok I will have a look I haven't got the book I don't think
				Re: Phone
				Posted: Sat Dec 21, 2013 11:31 am
				by fenj66
				The 4 digit pin might be on the side of the BT module as well. If not. A scanner should reveal the pin.
				Re: Phone
				Posted: Sun Dec 22, 2013 12:35 am
				by Steamyrotter
Correct.
Where are you (roughly)
Someone near you may be able to assist and or scan car.
				Re: Phone
				Posted: Sun Dec 22, 2013 7:56 pm
				by aneeque27
				[quote="Steamyrotter"]
Correct.
I have the same problem....whereabout are you steamrotter? I m in Romford Essex..
				Re: Phone
				Posted: Sun Dec 22, 2013 10:45 pm
				by Steamyrotter
				[quote="aneeque27"]
Correct.
About 200 miles from you i'm affraid..
				Re: Phone
				Posted: Mon Dec 23, 2013 7:34 am
				by charlie_bendall
				Anyone in Gloucestershire?
				Re: Phone
				Posted: Sat Jan 04, 2014 11:33 pm
				by Callum89
				I'm in Wiltshire
