So, I let him work his magic on the 4.8is.
It was booked in for Saturday at 1pm and I'm in Wolverhampton (testament to the fact that I am only willing to travel to to the right people to work on my cars). I set off at about 11am and headed down the M40. This gave me a good opportunity to stretch the legs on the 4.8 at different speeds with acceleration so I could give a good match to before and after the remap.
Got to Jason's at 1.30pm where I was duely met by Avtar (very nice meeting you paji...and your E70...seriously nice with the colourcoded aerokit). I handed the keys over to Jason and let him and the boys crack on.
They first check the car over to ensure it was sound and no faults before starting the actual work. Everything was good to go and the ECU was removed as on these they have to be mapped directly to the ECU and not through the port.
Jason asked me what my requirements were for the map. He did say that he could make it very aggressive if I wanted but it would be at the expense of fuel economy. Now I use the X everyday and its not really the kind of motor you need to prove anything in so I told Jason to not make it too aggressive but quick enough.
After sometime of adjusting settings, etc on the map, the ECU was put back in and the X was put back together.
After putting everything back together the fault memory was checked again to ensure no problems and he coded my X with driveaway locking for free...cheers Jason.
So, I hear you ask....THE verdict.......
Instantly felt the extra horses as I pulled away. The throttle has been adjusted at the sametime as adding the extra horsepower and when you push the pedal.....WOW what a difference. Considering it can be more aggressive if I wanted, I am mightly impressed. The power delivery is smooth and swift and the X pulls so cleanly and effortlessly and hurtles to triple figures unbelievably quickly. On the journey back up the M40 no matter what constant speed I started at, as soon as I pressed the pedal there was and instant pull in acceleration.
I've remapped nearly all of my previous motors and can honestly say that the increase is the most noticeable in the X5 over the other NA engined cars I have done before. If you're unsure on whether to or not.......Don't be. Just do it and you won't look back. So give Jason a call and get it booked in...
