Noise
Posted: Wed Nov 20, 2013 7:30 pm
by Doogal28
Hi , I've a 2004 4.4i sport , had it around 2 months and done around 1500 miles trouble free , however , I've started to notice a click / rattle at time when pulling away with the steering turned . It only makes two or three clicks then goes quiet once moving . No noise at all straight ahead no matter how hard i boot it . Makes the noise when turning without power on, just coasting . It doesn't do it all the time . The car had the outer cv boots replaced in 2012 according to the servicing invoiced i have . I was wondering if its a cv joint on its way out . Any advice would be appreciated . Car has done 65k miles
As I say it's not doing it all the time , appears to be on certain cambers and varying amounts of wheel lock
Apart from this love the motor , pulls like a train and sounds superb  :xmasgrin:
Re: Noise
Posted: Wed Nov 20, 2013 7:57 pm
by shadrack
sounds drive shaft- dont bother with cv joints use these:
http://www.ebay.co.uk/itm/BMW-X5-X-5-DR ... 1e585ff771
as found by me, jason at bw chiptune has also fitted them for a member after i recomended and thinks there great too
Re: Noise
Posted: Wed Nov 20, 2013 9:18 pm
by Doogal28
Thanks , I will check them out
Re: Noise
Posted: Thu Nov 21, 2013 7:12 pm
by malc1950
Are the driveshafts suitable for ,
My facelift 2004 e53 Diesel
Sent from my iPhone 5 using Tapatalk
Re: Noise
Posted: Thu Nov 21, 2013 7:48 pm
by shadrack
[quote="malc1950"]
check the listing but thats were i bought them from
Re: Noise
Posted: Sun Nov 24, 2013 9:27 am
by malc1950
Cheers will do
Re: Noise
Posted: Sun Nov 24, 2013 9:21 pm
by Raj
They fit all E53's. I've fitted them to my 4.8 too.
Re: Noise
Posted: Fri Nov 29, 2013 1:41 pm
by Doogal28
Just fitted one of the shafts from ebay to the passenger side front , very straight forward . Only had to drop the control arm off subframe and got enough movement on the hub assembly to get the shaft out of the hub . Left brake caliper etc all on. Impact gun got the centre 36mm nut off in a flash . All told just over an hour from start to finish . The noise has now gone so only doing this one for now .
Re: Noise
Posted: Fri Nov 29, 2013 1:56 pm
by Steamyrotter
Are you sure its not the indicators operating????  :-[
Apparently some of these were fitted with them.. >:D
Seems mine might not have been though.....
Re: Noise
Posted: Fri Nov 29, 2013 6:27 pm
by shadrack
[quote="Steamyrotter"]
i think maybe the indicators might be the only bit you have'nt replaced are they?
Re: Noise
Posted: Fri Nov 29, 2013 8:27 pm
[quote="shadrack"]
...........next week :P >:D
Re: Noise
Posted: Sun Dec 01, 2013 8:55 pm
by Steamyrotter
[quote="shadrack"]
Don't even go there!!!!
lol
