Bluetooth problems
shaunm41
Bluetooth problems
Hi, Ive been trawling through the topics on here and other forums about this and Im getting nowhere and need some help. Firstly i've just bought a 2004 (04) X5 3.0d sport. It has the speak button in the arm rest and ive located the ULF module in the boot. If I press the R/T button on steering wheel I get 'activate phone' on the dash but no matter what instructions I follow I cannot get into paring mode. I have disconnected the ULF module for 30 mins, I have taken the cradle apart to find the white plug disconnected inside, Refitted and secured that, found a blown fuse in boot, replaced that, briefly checked wiring in centre console, all looks ok. although I didn't get to look at the whole lot of wiring as I couldn't see it. Its doing my head in now, Any ideas......
Thanks in advance, Shaun
Colin
Re: Bluetooth problems
Hi Shaun, ive an 05 X and ive the same problem , (cant get paring mode ) i blame i phone , although my mate has an 05 X and he connected his i phone first time , i just gave up trying .. ps i followed all the correct methods for connection , but nout ...
05 , 30d Le Mans Blue Sport
- Lummox
I had the same problem when trying to set mine up using the button in the armrest. I used the button on the steering wheel and it went into pairing mode no problem but the phone wouldn't pair so I followed advice from this forum and deleted all my text messages and it paired no bother.
Lummox
Lummox
2004 54 plate 4.8is X5 E53 facelift in Carbonswarz-metalic.
shaunm41
Thanks for the replies. I've tried both the button in the centre and the steering wheel and still nothing.
I'm assuming it might not work with iphone 5s anyway but would like to at least try.
Shaun
Shaun
- Reusch
- Contact:
Me to I've given up trying with mine.
JFT96.YNWA
Current
Jaguar XF
Previous
BMW X5 3.0D
Current
Jaguar XF
Previous
BMW X5 3.0D
Parrot !
The trouble with the E53 is the technology was developed 12 years ago, when smartphones would be considered the devils work.
I would invest in a parrot hands kit, I have one in the van and they work perfectly with up to 4 different users, the later ones allow music streaming too. I've seen pictures of a member on here that had it installed into the ash tray, so kept the OEM look.
Have you cleared down the existing pairings? It might be blocking you from setting up any new ones.
Depending upon the model year, it may be that the version of the ULF in the car is too 'early'. BMW made some bad calls between 2000 and 2005 with Bluetooth and stuck with very early protocols long after the phone manufacturers moved on.
There are a lot of ULF versions as a result, and the later ones are the best ones. As above, a Parrot might be a better option.
Never anthropomorphise computers. They hate that.- briankerrys47
[quote="Horizon"]
Parrot !
[/quote]Thats the way to go lol. parrottttttttttttttttttttt
Parrot !
jongd1i
I have an issue and think il give up and go for a parrot. I can actually get mine paired and sync address book ok. I can even make the odd call through the speakers but after a few seconds it disconnects and need to use the phone again so pretty much unusable.
Sent from my GT-I9505 using Tapatalk
shaunm41
I might give it up as a bad job then. I'd av liked to keep it standard and use the steering wheel buttons but perhaps that's not gonna happen.
Most likely your only alternative if you want to stay OEM is to try to get the latest possible TCU, but I believe they are coded to the vehicle (especially if Telematics is included) which may mean you have to go to BMW.
Part number is: 84109236496
There were no less than seven GSM versions of the TCU in 2007 alone! That shows just how badly BMW got the integration of Bluetooth wrong.
A Parrot system is going to be both simpler and cheaper one suspects.
aldmc
I am looking at a Parrot system with maybe a Brodit cradle,
Problem being where to fit a cradle which doesn't get in the way or look stupid.
Maybe the armrest or tray install would be better without a cradle
X5 4.4 BLACK SPORT LPG 2002
ex
730d - 2004
E39 M5 - 2001
ex
730d - 2004
E39 M5 - 2001
Colin
Horizon i see you have a Dynavin head unit , whats that like , bluetooth etc etc , you get it fitted .
shaunm41
Just to update on this, I bought a BMW scanner and managed to get the Bluetooth into paring mode and paired up my iPhone 5s and I'm pleased to say its working faultlessly. Connects as soon as ignition is on, full phone book synced, calls are crystal clear, made a 20min call without a hitch, answer and end called with the button on steering wheel. I'm well pleased with it
Shaun
Shaun
Colin
Hi Shaun thats good news , i need one of them , name , website price etc etc , thanks, Colin...
