2006 x5 3.0L D low mpg
Posted: Sun Nov 03, 2013 9:45 am
by dan123ben
ok people what mpg is your car reading. mine seen to be using a lot of fuel even on a 200 mile drive its never goes over 25mpg. if I put £40 of fuel in it I get a about 165 miles does that sound high to you
Re: 2006 x5 3.0L D low mpg
Posted: Sun Nov 03, 2013 10:00 am
by Dimsum
I have just filled mine up and she had done 450 miles since the last fill up. 50 miles (at most) were motorway driving and the rest pottering around town.
On a motorway run? Well, we did Harrogate and back a few months back and that was 470 miles. I still had a quarter of a tank so she would probably have done near to 600 miles??
OBC shows 31mpg average and that seems to be my town driving average..
Its a late '03 facelift by the way..
Posted: Sun Nov 03, 2013 10:10 am
by dan123ben
looks like i am used to much them forgot to say am getting black smoke on acceleration to
Posted: Sun Nov 03, 2013 10:37 am
by Dimsum
Is the servicing up to date? Could be a factor.
I think a knackered MAF could cause both problems. Might be worth giving it a clean to see if it has any effect.
I am sure aomeone more technical than me could point you in the right direction!
Posted: Sun Nov 03, 2013 10:47 am
Black smoke an acceleration is normal providing it isn't excessive.
Cheapest so,Union will be to do an oil and filter change and an air filter change - good idea to change the crankcase breather at the same time. All are straightforward DIY jobs.
If that doesn't do anything then the MAF is an option as are the vacuum lines to make sure you have no leaks or disconnects. Any issues with acceleration (other than smoke)?.
Posted: Sun Nov 03, 2013 12:05 pm
by dan123ben
oil air fuel filters were done only 3000 miles ago. the car feels a little down on power to
Posted: Sun Nov 03, 2013 3:08 pm
Could be a vacuum hose then. If there is a leak the turbo boost drops and the smoke level goes up. Most of them are on the right side of the engine.
Posted: Sun Nov 03, 2013 6:26 pm
by Colin
i get 2 / 3 seconds of blue smoke on start up , whats that about ?
Posted: Sun Nov 03, 2013 6:30 pm
by 4687ah
Regarding the blue smoke on start up I asked that on here before and was told that it's down to the electronics over fuelling on purpose at start up, and is perfectly normal.
Edit- thinking about it I have reread the comment and mine was just a puff of smoke on start up not 2-3secs.
Posted: Sun Nov 03, 2013 6:41 pm
by Colin
thanks for that , its still not a pretty sight but at least its nothing bad ..
Posted: Sun Nov 03, 2013 7:52 pm
by malc1950
Don't worry mine has smoked on start up for the last two winters, I took it back to the dealer I bought it from and they sent it into a diesel specialist who said it was over fuelling on cold
Start up and it's nothing to worry about , but since then I have found I have two heater plugs down but it still starts ok on cold mornings ,
I will leave well alone till I have problems starting as I don't want to snap a heater plug in the head,
Sent from my iPhone 5 using
Tapatalk
