Good luck. The only slight difference from the guide when doing a rear door is you also need to remove the door catch assembly, otherwise you can't get the handle carrier past it. This is fixed by 3 or 4 torx screws on the shut panel. Also make sure everything is sitting just right before re-installing the small M5 bolt. It can be a cow to line up.
