Condensation
Posted: Thu Oct 24, 2013 9:29 am
by X5msd
Hi all
I every now and then get condensation on the inside of my screen
It's only just starting happening
Any ideas?
Thank you
Re: Condensation
Posted: Thu Oct 24, 2013 12:31 pm
by Denis O
The reason it's only just started happening is all this crap weather recently. You will also have water ingress somewhere in the car creating a damp atmosphere.
Quick fix is to keep the air con running. Then start searching for the water ingress.
Re: Condensation
Posted: Thu Oct 24, 2013 1:03 pm
It will just be damp air in the car.  Mine is doing it too and has no leaks.  As above, keep the a/c in use all the time and it will reduce condensation and stop the pump seals failing too.
Re: Condensation
Posted: Thu Oct 24, 2013 1:41 pm
by Nat
Hi,
Disagree with the other posts. If you have condensation inside the car, you have water ingress. End of .
When I say water ingress, its not always a major leak. Its enough to get into your car after being caught in the rain with a wet brolly, the inside of the car will steam up. Thats normal. However do that with blocked vents/drain holes and it has nowhere to go, so stays behind and keeps re-appearing.
The air con switched ON, with the re-circ button active acts as a dehumidifier, so as advised in the previous post will deal with the moisture, but it doesn't deal with the initial problem . The fact remains the car should be able to deal with a little moisture on its own. Thus inless uou deal/find out where the water has come from the problem will not go away.
Check under the bonet, all the channels and drain holes, rake out all the dead leaves/moss/twiggs etc etc and providing you dont have agenuine leak it should go away. Look at the sunroof drain holes ( comon area ) and of course the door bottoms.
Regards,
Nat.
Re: Condensation
Posted: Thu Oct 24, 2013 1:55 pm
Sorry but your comment is incorrect.
We currently have high humidity air about which has the ability to cause condensation in any vehicle kept outside.  Today my patio is covered in heavy dew, my home's windows have condensation on the outside and the car had condensation inside on the windows where the sun had warmed the car, but nowhere else inside.  The only water ingress to the car is from damp air via the open vents, not from any leaks.
A vehicle kept inside would most likely have a leak even if it was put away wet - in which case the water evaporates and permeates the car and anything else in the garage and makes things damp.  Heat that up and you get water vapour condensing on cold surfaces - again not a sign of a leak.
If it's 100% dry and then you get condensation that could well be a leak.  But a wet dog, coat, sweaty or wet body can do the same.
Re: Condensation
Posted: Thu Oct 24, 2013 2:06 pm
by Nat
Hi,
As they would say in my business............when there are oposing views is " we have a market".
Both my BMW's live outside and neither have any condensation on them. Dew on the ouside , sure but absolutely Nothing inside.
Whether you think im right or wrong I'd still check all the drainholes etc etc for debris.
Regards,
Nat.
Re: Condensation
Posted: Thu Oct 24, 2013 9:10 pm
by Reusch
Yes I've noticed a lot of condensation in mine now come to think of it but it's usually when I've been in the back seat with the mrs. Whey hey. :)).
Re: Condensation
Posted: Fri Oct 25, 2013 7:36 pm
by 535dboy
[quote="Reusch"]
In your dreams
Re: Condensation
Posted: Fri Oct 25, 2013 8:39 pm
by Reusch
Yup mate you got me there she was up for it when I was married to wife number 1 but not now.
Re: Condensation
Posted: Fri Oct 25, 2013 9:02 pm
by X5msd
Thanks for helping solve the problem
And thanks for adding more condensation
In the car
Re: Condensation
Posted: Sat Oct 26, 2013 9:29 am
by 535dboy
[quote="Reusch"]
Ha ha ha
Snap!
Re: Condensation
Posted: Fri Jan 17, 2014 10:48 am
by Caesium
Check the drains under the bonnet near the hinges, they fill with leaves.
My car doesn't get any condensation inside, but I have rubber winter mats so unlike the carpet ones they don't hold moisture.
Re: Condensation
Posted: Thu Jan 23, 2014 8:20 pm
by briankerrys47
Richard+1 ::)
