GENUINE BMW PROFESSIONAL 3 DVD MAPS
westside
Post by westside » Sun Oct 13, 2013 1:22 pm
I have for sale the following genuine DVD Europe MAP.  Theses will only work on the Professional DVD.
open to offers these are original not copies!
Re: GENUINE BMW PROFESSIONAL 3 DVD MAPS
Post by X5Sport » Sun Oct 13, 2013 2:17 pm
For those buying, you will also need to obtain a licence key from BMW @ about £180 as these are needed for CIC equipped vehicles.  The key is specific to your car and is derived from your VIN.  Without the key, these maps won't work correctly.
Annoyingly, the key only works once too.... >:(
Thanks BMW!! >:D
westside
Post by westside » Sun Oct 13, 2013 7:07 pm
i wasnt aware a key was required my e70 was non cic so no key was required.,  The x6 was cic with a hard drive so didnt require the discs
Post by X5Sport » Sun Oct 13, 2013 10:05 pm
The three discs you have look as though they are the ones that should be able to update any CIC drive as the upgrades can be done by the owner.  You just need a licence key to be able to use them.
Any CIC drive owner can get the same discs from a dealer and self load them which avoids a Dealer labour charge.  It's during the loading process that the key is requested.  Once loaded the system updates as you drive.  The discs are the cheap bit now.
westside
Post by westside » Mon Oct 14, 2013 9:25 am
so I assume a key wont be required if you dont have CIC
Post by X5Sport » Mon Oct 14, 2013 10:00 pm
I'm confusing myself now I think.
The older CCC system only took one DVD like the Mk4 nav in the E53 yes?  In which case your disc set looks like a CIC set so won't load into a CCC drive.  I've not seen a multi disc system for the CCC system before which is why I'm puzzled.
The discs appear to be Navteq which is CCC type and the CIC ones should be TeleAtlas - hence my confusion.
What did you buy them to go in.......?
shadrack
Post by shadrack » Mon Oct 14, 2013 10:37 pm
maybe you need a hobby?
current: 2016 Vw Crafter
Post by X5Sport » Tue Oct 15, 2013 12:30 pm
[quote="shadrack"]
I did have but they've just made me redundant........ >:( :'( :P
westside
Post by westside » Fri Oct 18, 2013 9:49 pm
hi BMW gave them to me when I had my e70 these are for CCC thats what my e70 had.  I dont think these work for CIC theses well be for CCC
