New Rear disc, pads and shoes need - what make would you recommend?
j2d
Post by j2d » Wed Sep 11, 2013 3:35 pm
Fail MOT again today on hand brake efficiency even after adjusting it at the weekend, so New Rear disc, pads and shoes need, Had a quote for £320 fitted! So decided to order the parts from Eurocarparts and do it myself.
They sell a few different brands, can anybody recommend which rear brake discs, pads & shoes to go for?
Thanks in advance
J
gchristofi
Re: New Rear disc, pads and shoes need - what make would you recommend?
Post by gchristofi » Wed Sep 11, 2013 4:09 pm
Pagid are probably the best that ECP sell. The only negative I've seen re pagid are occasional squealing issues.
Do try carparts4less too as they appear to be from the same place but far better prices (matching or surpassing ECP even with one of their 25-30% off codes included)
j2d
Post by j2d » Wed Sep 11, 2013 5:03 pm
Thanks for the info
Another question, if the low pad wear light hasn't come on yet, i'm guessing I won't have to fit a new wear sensor?
Is there much difference in quality between the Pagid, Eicher and Textar?
John
Post by Raj » Wed Sep 11, 2013 5:31 pm
John,
Do the discs and pads need replacing?
If they still have life in them then personally think you just need new shoes. Tbh after adjusting mine even with new shoes they still failed it and ended up getting the dealer to adjust them and then it was fine.
I've got pagid all round but will be replacing all my brakes next Saturday with something a little bigger.
Post by X5Sport » Wed Sep 11, 2013 5:32 pm
Pagid & Textar are both used OEM.  If the sensor hasn't tripped and it comes out OK then you don't need to change, but given the effort in you having ut all in bits, you might as well replace that too - well I would.
New shoes will also take time to bed in.  I always used the parking brake even though being an auto, the Park pawl could do the job.  I never trusted it not to break!!  Well it is a BMW innit.. :o
j2d
Post by j2d » Wed Sep 11, 2013 5:39 pm
Tbh the discs have had it! So going to change the lot.
Just ordered Pagid Discs, Pads and shoes for £100 delivered by the wkend from carpartsforless, Eurocarparts were £116 even with a 30% discount (HOT30)
Had the discs and pads off at the weekend so shouldn't take long to do again
I'm guessing changing the shoes  is pretty easy too?
J
Reusch
Contact:
Post by Reusch » Wed Sep 11, 2013 9:01 pm
I've got pasig all round but will be replacing all my brakes next Saturday with something a little bigger.
Ah Raj then will we see the piccies
JFT96.YNWA
Current
Jaguar XF
Previous
BMW X5 3.0D
Post by Raj » Wed Sep 11, 2013 10:29 pm
[quote="Reusch"]
I've got Pagid all round but will be replacing all my brakes next Saturday with something a little bigger.
Yes for sure lol
