battery light stays on
Posted: Sun Sep 08, 2013 7:23 pm
by fatladandy
Hi guys,
Been out in the x5 today and when i started the car the battery light stayed on until i blipped the throttle. It did this everytime i started the car. On the last occasion i left it idling to see if it went off on its own and until i set off it remained on.
I have not tested the alternator as yet as my meter is in work. Does anyone have any ideas what it could be?
Re: battery light stays on
Posted: Sun Sep 08, 2013 8:14 pm
by Sanj
How old is the car and then the battery? That's usually why the battery light will stay on - check the age.
Posted: Sun Sep 08, 2013 10:17 pm
It could also be the alternator output is too low.  That would be a regulator pack most likely.  Go with the battery first as Sanj suggests.  If it's more than 5 years old, or has been allowed to go flat a few times then it may well need a change.
Posted: Mon Sep 09, 2013 6:43 am
by fatladandy
Battery is 6 months old. Car is a 2002 4.4i sport
Posted: Mon Sep 09, 2013 8:40 am
Any loose connections on it?
The light is normally kept off by the alternator charge rate exceeding the power consumption of the vehicle.  If the 'balance' shifts to the battery discharge rate exceeding the alternator output then the light comes on.
Posted: Mon Sep 09, 2013 10:19 am
by fatladandy
I will check the connections tonight. I will also get my meter on it too.
