I was wondering if anyone on here has had their rear bushes replaced and what were the symptoms that revealed themselves...
I have had my front bushes replaced as I had steering wheel judder at certain speeds and when I took it to my local Indy he showed the travel of the wheels under low braking(quite an eye opener) :blink:
However I have a vibration coming through the chassis now,more noticeable at lower speeds accelerating gently in the lower gears..
Is this a symptom of worn bushes???
Gearbox is fine and shifts as it should and no un usual noises apart from when braking I gat a squeal from the rear but did notice the pads are close to the limit..
Will get Indy to look at it later in the week but thought I would try and get a heads up first from you guys...
How much roughly should replacement bushes be if they are gone???
Thanks in advance
John.....
