Hi,
I have a problem with my X5.
I am not sure if this is a coincidence or not but just after a car wash (no engine cleaning) I had the ABS light come up (10 min after the car was washed)
Then few days later TRANS SAFE FAIL PROG has come up, gearbox is going into the limb mode and lots of strange things happening:
- temperature gauge goes to maximum
- speedo drops to 0
- rev gauge drops to 0
The new battery has been fitted today. It did not change anything.
I went to the transmission specialist. He plugged in the computer, and checked the abs connection, but said it was fine. He said that there is a small chance that it is a transmission problem, and more likely it is something to do with abs.
He said that the gearbox will go to the limb mode if there is a problem with anything to do with wheels turning related stuff.
Here is the reading:
DME/DDE 2F
(Motor/Diesel Electronics)
221 CAN Timeout ASC/DSC
220 CAN timeout, electronic transmission management (EGS/AGS)
EGS 2F
transmission control
128 CAN bus Monitoring
130 CAN ABS/DSC signal
Has anyone had a similar problem and would be so kind to tell me what to check/do next.
Thank you in advance.
BMW X5 4.4i 2001 - ABS + TRANS SAFE FAIL PROG
Patrick
