I put power onto Pin 1 on the Webasto itself and the unit is starting - though I don't think it is running/sounding as it should (did not hear the fuel pump kick in and got nothing from exhaust?)
Problem is now though after todays mucking about, checking fuses etc etc neither of my Keyfobs will lock/open the car. I have just tried the 're sync' procedure - that is when sitting in car with all doors closed turn Ignition to position 1 (5 times quickly), hold 'unlock' and press lock three times, release unlock. Door should lock then open - then re sync second key. I have done this succesfully in the past though 'nothing' today????
Any ideas greatly appreciated - been a long day stuck in the boot and am pretty pissed off! I did think for a while with all the playing about powering up the webasto etc it could be low battery issues but have just started the car no problem - any help really would be appreciated.
