hidden menu
Posted: Wed Aug 07, 2013 8:27 pm
by jaynana
can somebody remind me how to get the hidden menu on the dash. i can't seem to find it..
i want to see the battery voltage display...
thx
Re: hidden menu
Posted: Wed Aug 07, 2013 8:49 pm
Re: hidden menu
Posted: Wed Aug 07, 2013 9:13 pm
by jaynana
yes! thanks
Re: hidden menu
Posted: Wed Aug 07, 2013 9:24 pm
by snipez999
I generally prise the dashboard apart very carefully with a fork, then I can grab the edge of the menu and pull it out.  However, you could always just check the takeaway's number on Google and call them up without bothering to do this.........
Re: hidden menu
Posted: Wed Aug 07, 2013 9:35 pm
by jaynana
[quote="snipez999"]
lol
Re: hidden menu
Posted: Tue Sep 10, 2013 11:33 am
by Ant
does this work ?
I followed the link, printed the advice but I cannot get into the 'hidden menu' on my E53 !!
Press and hold right button - done
Test Nr.01 - done
press left get chassis - done (added up also comes to 22, a '0' is zero and not 'ten' when adding up isnt it ?)
press right till I get to Nr.19 - done
press left - lock off, lock on lock 00, 01,02,03 upto relevent 22 (matching chassis) - done
press right for hidden menu - FAILURE, I just get 'Nr.01' again
Tried in with key in position 2, and with ignition on
What am I doing wrong ?
Re: hidden menu
Posted: Wed Sep 11, 2013 11:23 am
by ChrisLux
[quote="Ant"]
does this work ?
Test Nr.01 - done
Well this link is for E38 7 series , but E53 does have the hidden OBC menu too , all BMW's do , but it's slightly different to get into each model I think .
Try this version ;
2 buttons/pins on the speedo one resets the mileage counter (left) and the other to alternate the obc view (right)
1. Press and hold right button till u get TEST NR 01
2. Press left button
3. Add up all the numbers this is your unlock code. Example 26131=13
4. think right takes u back to TEST-NR 01
5. Press right till u get too TEST NR 20 then left
6. Get locked message hit left till u reach ur unlock code then right
7. Goto TEST NR-09 and hit left
Hope it works
Re: hidden menu
Posted: Wed Sep 11, 2013 11:36 pm
by X5 ALN
can you post a pic of the menu on your display - just being curious.
Re: hidden menu
Posted: Thu Sep 12, 2013 6:48 am
by ChrisLux
[quote="X5 ALN"]
I would do , except I'm in Lux and the Missus is in UK with the X5 , but I can do when I see it again  ::)
Re: hidden menu
Posted: Thu Sep 12, 2013 11:20 am
by Ant
I did try it yesterday with the engine running (wary of playing with electrics while engine is off as I think the battery is failing, hence the reason to view the hidden menu battery setting)
I got as far as:
I got to NR 20, pressed left and I got no locked message but got:
KVER1000 which counted 'down'.... so I switched the ignition off
I will try again with the ignition in position 2
Re: hidden menu
Posted: Fri Sep 13, 2013 4:30 pm
by Ant
Tried it with ignition in position 2
Still get KVER1000 whatever that means ?
why is it everything others find so simple, I balls up  :-[
