problem tyres
Smeeagain
problem tyres
Post by Smeeagain » Tue Aug 06, 2013 2:43 pm
I hope someone can help me - about 3 months ago i bought Vredestein Sessanta tyres for tyremen.co.uk _ I ordered a pair of front and a pair of rear at the appropriate OEM sizes
But the tread pattern confuses me - its like I have a pair of assymetrical (sided) tyres - two of the same. but nowhere on the tyre does it say they are sided or that they are directional etc. But if you look at the pic it looks like the read pattern is acting in opposing directions - what do you think? I havent posted a pic of the front but they are the same
Re: problem tyres
Post by X5Sport » Tue Aug 06, 2013 3:34 pm
Looks alright to me......try Googling that tyre for other images to see if they're the same..... :)
If they were directional then I would expect a mirror image, but if they aren't then the grooves are all in the right places.
R
Sanj
Re: problem tyres
Post by Sanj » Tue Aug 06, 2013 5:07 pm
The pattern isn't the same - I can see that. Think the one on the right is correct and the one on the left should be on the right (when it's presented to that side the pattern is the same as you're other one)!
Look for an arrow pointing in the correct forward rotation (see Richard's post here) or the word 'outside' on the tyre wall.
Incidentally - are they all the same size?
Denis O
Re: problem tyres
Post by Denis O » Tue Aug 06, 2013 5:27 pm
I just put Sessanta's on my Z4, also from Tyreman, and the rim on each tyre has "Outside" in raised letters. I can't see it would be any different for larger tyres.
05 Mercedes SL350
Re: problem tyres
Post by X5Sport » Tue Aug 06, 2013 6:08 pm
Which would still make that pair correctly mounted as the word 'Outside' would still be on the outside......if it also had a rotation marker then it would also confirm.  On both the main groove is on the inside edge of the tread.
Smeeagain
Re: problem tyres
Post by Smeeagain » Tue Aug 06, 2013 6:12 pm
yep but if you imagine the tyre rotating through standing water it just looks as thought the 'swoosh' tread pattern is doing different things on the opposite sides or am I looking at it wrong?
Re the tyres on Z4 I did find a website that said that the 'outside' lettering often appears on tyres on performance cars. much as I love my X5 I'm not sure I'd describe it as a performance car. But there is definiitely no OUTSIDe wording on it anywhere.
Smee
Re: problem tyres
Post by X5Sport » Tue Aug 06, 2013 7:01 pm
It does look that way I agree.  Looks like it chucks everything into the left side?
I wonder if it says 'Inner Side' anywhere?  Looking at the mages on the web, all the pairs are exactly the same as yours.  Even a piccie with all four looks like that.
Smeeagain
Re: problem tyres
Post by Smeeagain » Tue Aug 06, 2013 7:02 pm
Sanj- the front are different size to the rears
smee
Re: problem tyres
Post by X5Sport » Tue Aug 06, 2013 7:07 pm
Example......
Re: problem tyres
Post by Raj » Tue Aug 06, 2013 8:06 pm
They are correct as shown with Richards pic. Does look odd but is the way they are supposed to be.
Smeeagain
Re: problem tyres
Post by Smeeagain » Tue Aug 06, 2013 9:37 pm
Thank f*** for that. Looks really odd though
Thanks to everyone
Smee
Sanj
Re: problem tyres
Post by Sanj » Tue Aug 06, 2013 10:45 pm
Think they look wrong though...
CondorX5
Re: problem tyres
Post by CondorX5 » Wed Aug 07, 2013 10:13 am
I have Sessantas on my summer wheels, will photograph them and check. I thought they looked good, not wrong.  :) perhaps I didn't notice!  Have you called Tyremen? They are actually quite helpful.
Imy
Re: problem tyres
Post by Imy » Wed Aug 07, 2013 11:32 am
I dont see how the tyre on the right would disperse ground water correctly...
Re: problem tyres
Post by Raj » Wed Aug 07, 2013 12:27 pm
It's because both are pushing the water inwards which would provide more stability than if one was pushing the water inwards and other outwards which would push the rear to one side more at speed (aquaplaning).
