Rear brake wear sensors
Steve Blackdog
Post by Steve Blackdog » Thu Jul 18, 2013 6:46 pm
Hi folks
I am just wondering how many brake wear sensors I will need when I change my rear pads - are there one or two needed?
Steve
Re: Rear brake wear sensors
Post by X5Sport » Thu Jul 18, 2013 6:48 pm
One front, one rear.  So just one for your job.
gmc15
Post by gmc15 » Thu Jul 18, 2013 7:48 pm
Think it's front near side and rear off side where they are. If you change the pads before the light comes on the dash you will not need new sensors. If the light comes on then the sensor has had the wire worn away by the low pad thickness. It only takes one of the two sensors to activate the light, so you will need to find out which one has worn.
x6 M50d
Steve Blackdog
Post by Steve Blackdog » Thu Jul 18, 2013 8:01 pm
Thanks very much for your speedy answers.  This is such a helpful forum!
My check brake linings went on just as I was setting off on a 500  mile round trip. Not sure how much of the sensor will be left by the time the discs and pads are fitted ;)
Denis O
Post by Denis O » Fri Jul 19, 2013 5:35 am
ECP running a 30% off deal on brakes at present. Use HOT30 as your code.
05 Mercedes SL350
4687ah
Post by 4687ah » Fri Jul 19, 2013 9:12 am
I just did the rears on mine, i used that code and off memory, it was about £26 without sensors, free delivery.
2006 3.0d Sport, Carbon Black,Comms pack with Assist,Climate pack,Premium + Sport Plus pack, Nappa leather,pano roof, and Comfort seats - which is sadly now sold and has been replaced by a Mazda 6, oh well shit happens.
