Xenon's self levelling?
Imy
Post by Imy » Thu Jul 18, 2013 1:52 pm
I recently replaced my crappy halogen units for some second hand xenon projectors. They came with the ballasts and bulbs.
I dont think the self levellin is working, and also when I use the light height adjuster in the car nothing happens.
Has anyone got any experience of this and any rectifications?
Thanks in advance
Sanj
Re: Xenon's self levelling?
Post by Sanj » Thu Jul 18, 2013 2:56 pm
That's right buddy - the Xenon equipped cars never had a height adjuster (the switch was different too). They're self levelling in OEM fitments.
Post by X5Sport » Thu Jul 18, 2013 3:23 pm
Are the levelling system wires connected in the headlight units?  Any sound from the drive/stepper motor assembly?  Did you get the Xenon control unit that is also needed for OEM light units - not sure if that is part of the OEM Ballast Assembly or not?
This Data Sheet might help.......
Imy
Post by Imy » Thu Jul 18, 2013 4:13 pm
Thanks guys.
Richard Il check through the documents when I get home. When I start the car the lights come on and nothing happens. When I try and adjust the height with the control unit next to steering wheel, again nothing happens, does this mean i need to do extra work?
I just assumed that as I got all OEM parts that it would work no problem.
Edit: Sanj was there no manual adjustment switch for xenons inside the car then?
Post by X5Sport » Thu Jul 18, 2013 6:55 pm
No prob, and no there is no manual adjust on OEM Xenon equipped versions.  The regs require new builds to have auto height adjust and headlight washers.
The lamp units should have a little stepper motor inside which is connected to the Xenon light electronics.  It may just be a case of plugging it in.  :)
The document does say E38 but actually has a diagram showing an E53 light unit in it.
Imy
Post by Imy » Fri Jul 19, 2013 11:33 am
Richard,
Its definitely plugged in  >:D
Ball ache as I think they are pointed too high, i adjusted them manually but still doesnt look right.
Black X5
Post by Black X5 » Fri Jul 19, 2013 7:34 pm
I did this on my pre- facelift E53.
Just plug and play- and the manual adjuster worked fine from the dashboard.
As said already- the motors should be heard to move. Also they are switched on, mine from memory used to move up and down, before resting at their set position.
If all wires are connected and the previous lights worked correctly I'd say there is a problem with the lights.
E70 3.0D SE, Black with Black - Gone but not forgotten!  >:D
Pope
Post by Pope » Mon Jul 22, 2013 7:54 pm
Imy
How easy/hard was it to fit the headlight units..??
I'm thinking of doing the same conversion to my 2009 none xenon E70, so any help/guidance would be greatly appreciated.
Oh, and does anyone know whats the difference between Xenon and Bi-Xenon light units??
:pope:
Garage:
BMW X6 40d Pink
Ducati Diavel 1198 Carbon
Post by X5Sport » Mon Jul 22, 2013 8:04 pm
It usually means they provide both dip and main beams from one bulb.  The beam pattern is altered by a mechanical shutter that moves out of the way when the main beam is selected.
That is certainly what is fitted to my X6 and Mini, both equipped with OEM Bi-Xenon lamp systems.  The X6 has no 'inner' main beam lamp as the H8 angel eye source is in that position.  The inner projector is fake for maintaining a 'brand face' for the car.  Pointless IMHO and much better used as a proper main beam projector.
Pope
Post by Pope » Mon Jul 22, 2013 8:18 pm
Ah, right oh Richard, thanks for clearing that up.
Brian
:pope:
Garage:
BMW X6 40d Pink
Pope
Post by Pope » Mon Aug 19, 2013 5:44 pm
Calling Imy..
Having got myself a pair of Xenon headlight units complete. I'm now having trouble finding a Garage willing to do the upgrade (in Luton).
Did you fit yours, or did a garage do it for you, if so can you tell which garage you used??
any help info greatly appreciated.
:pope:
Garage:
BMW X6 40d Pink
