T91 Telestart for remote heater
paulbryson75
Post by paulbryson75 » Sat Nov 20, 2010 8:40 pm
I have a T91 telestart for my auxy heater - bought this last year from someone off the old site and it worked great. Problem is i did not have the correct 6 pin connector - i wired up the three wires direct to the unit, one of these wires has now come out and I can not remember or find the instructions as to which wire goes to which pin!!!
I have a white/green wire, Red/Black wire and a Brown wire?????? Need to know which wire goes to each pin??? 6pins only three wires
Can't remember whom I bought it off but he sent me instructions on how to wire - of course have lost these!
Anyone know where i could source the 6 pin connector plug???
In the photos below the 'plug' goes where you can see the three fine wires going into the unit - bottom right of photo
Thanks as always
Paul
02 X5 3.0d SE - Mods: Double exhaust, Angel eyes, orange bits removed! M-Sport steering wheel, e70 X5 Alloys, Aftermarket Sat/Nav DVD with rear screen, Webasto T91 Telestart, skid pan.
apetrov1x5
Re: T91 Telestart for remote heater
Post by apetrov1x5 » Tue Nov 23, 2010 9:11 pm
that;s it?! you are not gonna explain us how do this too? I really wish I would have something like this on my car.
paulbryson75
Post by paulbryson75 » Tue Nov 23, 2010 9:23 pm
The telestart is the means of operating your Webasto heater as OEM fitted. Units are source (usually from German EBAY) to include the telestart module, which plugs into the boot into the wiring loom behind the battery. An antenna can also be fitted. A key fob - with on and off button is then used to start/stop the auxy heater. My unit originated off a landrover/range rover.
Audis, mercs, RR, Skodas as well as 5/7 series all have webastos and there is a huge amount of info on the web - i have trawled loads of it this weekend!!
I bought my telestart off a guy on the old X5 site - really is great mod - though have had problems - would appear as of today to have been caused by a done battery.
When the auxy heating option was ordered at build BMW charged I believe in the region of 600 quid to supply the telestart and key fob - you can do this yourself for well under 100. There is another way of activating the webasto - see extensive post in the 'how to' section for even less money and equally as effective.
If yours comes with the correct plug it simply plugs into the BMW plug - Mine did not come with plug hence the need for me to wire direct to the pins.
apetrov1x5
Post by apetrov1x5 » Tue Nov 23, 2010 9:29 pm
thank you, I am going to read into this...tempted.
How many times it drained your battery though?
X MAN
Post by X MAN » Tue Nov 23, 2010 10:42 pm
[quote=""paulbryson75""]Anyone know where i could source the 6 pin connector plug???
Try this part number 61 13 6 909 058 it`s a 6 pin male connector. 61 13 0 005 197 are the pin contacts with a lenght of wire
that fit into the 6 pin male connector. Take your telestart module along to the dealers and see if the 6 pin male connector fits into
the telestart module before you purchase ,if it doesn`t ask them for one that does.
Regards x man
05 X5 3.0d
Mods:H/s wheel.F/mirrors.Lumbar.Compass-remote r/v mirror.Rem ctrl.Bins holder.T90 Telestart.20"168's.Arches.Titan grills.Skid plate. P/O load floor.R/seat e/b/rest.R/blinds.H/rear seats.is r/bumper trim.chrome dials.car key mem.intravee.DSP.RV Cam.Dbl glazing.Ski bag,Rear blower
paulbryson75
Post by paulbryson75 » Wed Nov 24, 2010 12:43 pm
Cheers x man will do that. At moment have just wired it with little pins from maplins not ideal!
Draining battery- only twice but this would appear to be due to the cars battery as opposed to any fault with the heater
Minda
Post by Minda » Wed Nov 24, 2010 7:53 pm
Can i get one for my E70? if so where from?
Sanj
Post by Sanj » Wed Nov 24, 2010 8:00 pm
[quote=""Minda""]Can i get one for my E70? if so where from?[/quote]
No! Them cars are rubbish - E53's were always the best! :rofl:
Seriously though - only poss if you have the heater already fitting. A right pig of a job to retro-fit if not one that most won't take on.
Minda
Post by Minda » Wed Nov 24, 2010 8:31 pm
[quote=""Sanj""][quote=""Minda""]Can i get one for my E70? if so where from?[/quote]
Seriously though - only poss if you have the heater already fitting. A right pig of a job to retro-fit if not one that most won't take on.[/quote]
How do i find out if i do?
Sanj
Post by Sanj » Wed Nov 24, 2010 8:48 pm
Look under the hood for anything called a Webasto - they may be a different manufacturer on the E70 but on the E53 that's what they were.
Pic here:
viewtopic.php?f=8&t=625&p=6987&hilit=webasto#p6987
Post by X5Sport » Wed Nov 24, 2010 9:22 pm
I was wondering the same thing about X6 diesels. I'm told the nits may not be in te actual engine bay, but might be in the front wings. Apparently you should e able to find te exhaust unit underneath. Can't see one on mine but tn 90% of the underside is covered in aerodynamic & protection covers. These things must e ightmare to work on given half the car has to come off just to be able to see things!
I'll have another look under the hood tomorrow. The new units are completely different though and might be a Thermo Top Evo 5+ or Themo Top P. I suppose it might be in the wings given they are plastic ( sorry, High Quality, Lightweight Materials ). :D
paulbryson75
Post by paulbryson75 » Wed Nov 24, 2010 11:46 pm
X5Sport - if you don't find it don't worry - i'll happily swap my 02 e53 with Webasto for your X6 without :D :D :D :thumbsup:
Post by X5Sport » Thu Nov 25, 2010 9:03 am
Er...............you'll have to join the queue :D
I'm already checking the stairs for tripwires hourly as SWMBO has her eyes on it too........... :( :? :fuelfire: :cry: :driving:
Rick
apetrov1x5
Post by apetrov1x5 » Sat Nov 27, 2010 10:29 pm
can someone please write a how-to with LOT of pics ? please, it is -6 here in Edinburgh and sometime the door is frozen :(
