OBD goes of and flickers on and off
bemdblu
Post by bemdblu » Sun Jun 23, 2013 2:58 am
my OBD flickers on and off sometimes
then comes back on later or a day later
any ideas
Thanks Jack
Colin
Re: OBD goes of and flickers on and off
Post by Colin » Sun Jun 23, 2013 7:15 pm
Hi Jack ,  mine does the same from time to time , i also get a crackling in the speakers some times , i asked on here and was told it could be a bad connection in the ribbon cable in the head unit , or a module in the boot , where do ya start ... mine hasnt done it for a few weeks now so i left it alone , you can check back on some older  threads for the same problems and get some more fix info , good luck . Colin ...
05 , 30d Le Mans Blue Sport
Steamyrotter
Post by Steamyrotter » Mon Jun 24, 2013 1:35 pm
depends which one it is??
Need Car model & Year and if SAT Nav or not to be able to give a more robust answer
