will disco wheels fit an e53 ?
x555
Post by x555 » Thu Nov 18, 2010 7:53 am
Does anyone know if landrover disco 2 wheels would fit the e53? the stud pattern looks the same but they are 16" wheels with 235/70R16 tyres on them.
Not great wheels but was considering them for a winter set up maybe!!!
Juat wandering if the 16" would clear the brakes etc as the smallest is usually 17" for the e53 i think.
Re: will disco wheels fit an e53 ?
Post by X5Sport » Thu Nov 18, 2010 10:57 am
Stud dimensions and offset will be critical. The other issue is as you say, will be the brake discs and calipers, as in whether the disco wheels will physically fit over them whilst still allowing cooling air flow. No idea on that one.
The handling might be kind of 'interesting' given the hub size. You will also need to check if the 'rolling diameter' of those tyres is the same as the X or the speedo accuracy will be adversely affected.
bullethead
Post by bullethead » Thu Nov 18, 2010 11:08 am
I think new disco wheels will. Only saying that cos when I bought the wrong right wheels :roll: for mine the geezer had them on a disco.
CondorX5
Post by CondorX5 » Sat Nov 20, 2010 9:38 pm
The BMW recommended size for winter wheel set up for E53 models (not the 4.8is though) is 17" - not sure if the 16" will clear the brakes?
Otherwise, I *think* the offset is ok and I know many Range Rover / Disco owners have fitted E53 X5 wheels directly to their cars, so if the brake clearlance is a non-issue, then you should be ok.......will probably look pretty grim though....... :D
paulbryson75
Post by paulbryson75 » Sun Nov 21, 2010 2:36 pm
just noticed on ebay a set of 17inch X5 wheels with Michelins - claimed good condition - in London, currently at a bid of 50quid! Ending this afternoon (sunday) can't be bad!!! (nothing to do with me by the way)
http://cgi.ebay.co.uk/BMW-X5-ALLOY-WHEE ... 500wt_1156
02 X5 3.0d SE - Mods: Double exhaust, Angel eyes, orange bits removed! M-Sport steering wheel, e70 X5 Alloys, Aftermarket Sat/Nav DVD with rear screen, Webasto T91 Telestart, skid pan.
x555
Post by x555 » Sun Nov 21, 2010 6:10 pm
Thanks for the replys guys and gals.... just spoted some disco wheels the other day that already had winter tyres on and thought mmmmmmm cheap option for a winter set up,and then came to my senses and thought nahhhh they would look worse than the oem 17"s :stir:
