Broken Glove box
B1GGM
Broken Glove box
Post by B1GGM » Thu Jun 06, 2013 4:37 pm
Since I bought the x5 I've had the slight annoyance that the glove box has been broken and would not open regardless of whether or not the lock was open. I could live with this as I just didn't use the glove box. Simple enough fix as I'm sure you'll agree! Well so I thought until last week when a rattle developed coming from the passenger side near the footwell. Further investigation indicated that it was indeed coming from within the glovebox! Nightmare!
Google couldn't come up with an answer how to open the glovebox without removing the whole unit or the airbag from above it. I decided to try and find a fix myself. I took one of the spanners from the tool kit and managed to slide it between the top of the glove box and the dash. This provided enough space to reveal 4 Phillips screws across the top of the glove box. I removed these 4 screws which allowed the glove box door to drop slightly further down And provided access to the lock mechanism. I released the 2 metal tabs on the lock using a flat head screwdriver and the door opened onto my lap. :) The issue was clear as the rear of the lock on my glove box was in pieces in the glove box itself and the screws from the lock hanging loose were what caused the rattle. I put the lock back together and tightened the screws. Lifted the glove box back up and replaced the 4 Phillips screws across the top of the glove box. I now have a perfectly working glove box :)
A short crappy video showing my success ha ha First thing I have ever fixed myself when it comes to a car :)
P
