Calling all you Audio guru's! :)
Posted: Thu May 30, 2013 4:18 pm
Hey Guys,
I had my X converted to LPG a couple of weekends ago (I will put another thread about the install etc.) The installers had to take out my factory subwoofer to put the air compressor pump in that right hand cupboard.
Not that the OEM subwoofer gave that much bass but now its soo tinny. I cannot stand the sound of no bass so I've treated myself to an:
"Orion HCCA 12.2 subwoofer" (HCCA122 (12inch Dual 2ohm) - Orion Card Audio) and I wanted to go for the "Orion HCCA 5000 amp" to match but haven't got the funds at the moment so I have an old "JL Audio 1000/v2 Monoblock Class D" (1000/1v2 - Car Audio - Amplifiers - Slash v2 - JL Audio) lying around so I plan on using that for the time being just need to get the connections setup.
I know this has probably been asked a million times and I have read the How To's but I seem to read different install information depending on each person and which factory options they have.
So from factory I have:
Here are the different options I've seen for tapping the audio:
1. Tap a connection from the OEM sub connector which plugs into the sub. (Post factory Amp)
As shown by BSW in this video - http://www.youtube.com/watch?v=c0uM8FcSb3c
2. Tap a connection from the feeds to the factory amp from the 16:9 screen (Pre factory amp)
3. Tap a connection from the rear outputs to speaker doors and use a hi to low convertor (Post amp)
I've heard it's best to get a "clean" signal that hasn't been through factory amp is this right??
Also do I need to get a cable that converts them from 2 normal wires into a Phono plug for the amp phono inputs?
Could someone please recommend which method would be best suited for me?
I need to get a new battery as my Bosch S5 is starting to play up. Typical! just after the LPG tank is in the way now I am thinking about getting a Bosch S6 AGM battery does anyone know if this will fit in the standard place and is it a good battery for car audio?
Thanks!
James
- Nav 16:9
- DSP amp
- Professional Hifi Upgrade (Extra speakers in rear doors and factory sub in boot cupboard)
Thanks!
James
