	Heavy steering on 2001 X5 3.0d
				gareth82
Hi I recently bought a 2001 X5 3.0d.  Delighted with it so far just ironing out the wee problems with it.  The steering on it is very heavy, is that the way these are?  Power steering fluid level is fine.  Is it worth while changing the fluid and would it lighten the steering?
thanks
			thanks
2001 X5 3.0d sport
				thedweeb
Re: Heavy steering on 2001 X5 3.0d
Are you getting any starnge sounds i.e belts slipping.
Dweeb
			Dweeb
				gareth82
[quote=""thedweeb""]Are you getting any starnge sounds i.e belts slipping.
Dweeb[/quote]
Hi no strange sounds at all and all feels tight and the way it should, just heavy
			Dweeb[/quote]
2001 X5 3.0d sport
				thedweeb
I'd change the fluid As its cheapest thing to do and fingers crossed may sort the problem.
dweeb
			dweeb
				petert
Worth doing a cross-check with a smilar model/year - may just be different to what you were used to but on the other hand the power steering may be goosed.  Not a small car and the diesel will be heavier weightwise at the front but perhaps BMW account for that in the car's set up.
Peter T
			Peter T
				gareth82
Thanks for the reply's what's the best/easiest way to change the fluid and what power steering fluid does it need and how many litres?
Thanks again
			Thanks again
2001 X5 3.0d sport
						- paulbryson75
I find mine can be a little heavy at times (2002), especially say when going very slow - then for some reason seems to sort it self out again. Doesn't happen all the time though - one of those strange little things!
			02 X5 3.0d SE - Mods: Double exhaust, Angel eyes, orange bits removed! M-Sport steering wheel, e70 X5 Alloys, Aftermarket Sat/Nav DVD with rear screen, Webasto T91 Telestart, skid pan.
				thedweeb
[quote=""gareth82""]Thanks for the reply's what's the best/easiest way to change the fluid and what power steering fluid does it need and how many litres?
Thanks again[/quote]
Go to the castrol website, put in your reg, it will then list all of the fluids needed and qty.
				gareth82
[quote=""thedweeb""][quote=""gareth82""]Thanks for the reply's what's the best/easiest way to change the fluid and what power steering fluid does it need and how many litres?
Go to the castrol website, put in your reg, it will then list all of the fluids needed and qty.[/quote]
Thanks mate been a great help, is the method of a turkey baster to remove old fluid then replace with new ok, I guess this would need done a few times to remove all of the old fluid.
cheers
cheers
2001 X5 3.0d sport
				thedweeb
I would say you need to get all the fluid out of the rack and not just the bottle. I did one years ago on a vauxhall...If i remember correctly I disconected one of the pipes from the rack or there may have been a drain plug not sure so you will need to check. Once all the fluid is out refill the bottle, start the engine then turn the steering lock to lock to blead out the air. Some other members may want to chime in as its been about 15 years since i did one.
Regards
Dweeb
			Regards
Dweeb
				blingsta
the steering on my X5 3.0D is soooo much heavier compared to my little run around polo. but if i drive the X for a few days, it feels like normal again..  its a tank of a motor
