LED Sidelights
Ant
LED Sidelights
Post by Ant » Sun May 05, 2013 2:45 pm
I was going to tempt fate and try and swap the sidelights to some newer 'whiter' LED bulbs so they match the zenon headlights better.
I was looking at these as they say they will be 'error free':
http://www.ebay.co.uk/itm/2x-5-SMD-ERRO ... 3376c01eb8
But I have checked on BMW OEM and it says the sidelight bulb is part number 63217160795 and on Google images it looks like this:
Now, to me the connections look 'off set' ?
Has anyone changed these bulbs, and are the sidelight bulb connections off set ??
E30 320i
E36 325i Coupe
E46 330i SE
Now an E53 4.6iS
dpbayly
Re: LED Sidelights
Post by dpbayly » Sun May 05, 2013 4:09 pm
Do the Xenon headlights in the E53 use a different type of side light bulb to the non Xenon headlights as mine that I changed a few days ago were 501 type like these:
http://www.ebay.co.uk/itm/2-Xenon-5SMD- ... 257d9cb83f
SimonSingh
Re: LED Sidelights
Post by SimonSingh » Sun May 05, 2013 7:24 pm
I'm getting all the LED lights in for the X5's, what's the chassis (last 7) of your X? :)
Re: LED Sidelights
Post by AW8 » Mon May 06, 2013 9:02 am
Gents.................PM more appropriate if wanting to share retail & VIN info
Ant
Re: LED Sidelights
Post by Ant » Mon May 06, 2013 10:09 am
dpbayly, I dont know to be honest, looked at the ones you had and I cannot imagine how they fitted into a round socket as they look to have an end like a USB connection, but if they work for you then they obviously did fit.
Hope they look good  :)
E30 320i
E36 325i Coupe
E46 330i SE
Now an E53 4.6iS
dpbayly
Re: LED Sidelights
Post by dpbayly » Mon May 06, 2013 6:38 pm
I see,the Xenon headlights must definitely run a different side light bulb fitment in that case.
They do look good 100% improvement over the yellow look
Jamee
Re: LED Sidelights
Post by Jamee » Mon May 06, 2013 7:20 pm
I just bought normal 501 bulbs like these.
http://item.mobileweb.ebay.co.uk/viewit ... 5685987224
Black BMW E70 35D
Previous:
: Tuned Black E53 3.0D Sport
: Tuned and custom E46 facelift BMW 330ci clubsport in estroil blue
Jayx5
Re: LED Sidelights
Post by Jayx5 » Tue May 21, 2013 9:42 pm
[quote="Jamee"]
I've just fitted these and there really white and go well with the xenons :)Image
2010 space grey se dynamic pack and lots of toys
Ant
Re: LED Sidelights
Post by Ant » Sat May 25, 2013 10:06 am
What bulbs were they jayx5 ?
E30 320i
E36 325i Coupe
E46 330i SE
Now an E53 4.6iS
Jayx5
Re: LED Sidelights
Post by Jayx5 » Sat May 25, 2013 11:13 am
[quote="Ant"]
Hi ant, they were canbus 501 (w5w) 5 smd led error free from hids-direct £8.99 delivered. Hope that helps :)
Ant
Re: LED Sidelights
Post by Ant » Sat May 25, 2013 11:56 am
Wow, there are loads to choose from  :)
I really need to pull my sidelights out of my car and have a look as I am really stumped how these fit ?
My bulbs (as far as replacement bulbs on the internet have shown me - hence I should really look in person) are an 'offset pin - round base' fitment that you slot in and twist to secure, yet these look like USB stick fitments, how do they work ????
Do you just 'ram' them in ?
E30 320i
E36 325i Coupe
E46 330i SE
Now an E53 4.6iS
Jayx5
Re: LED Sidelights
Post by Jayx5 » Sat May 25, 2013 2:17 pm
Once the holder is out (push and twist) pull out the old bulb and push the new straight in, about 2min job.
Ant
Re: LED Sidelights
Post by Ant » Sun Jun 02, 2013 11:36 am
As I was getting more and more confused, I finally got off my behind and went and actually looked at the bulbs in my car, guess what, everyone was right, they are little USB like connection that just slip in  :-[
I am useless with DIY, my mind works it out but my hands ignore me, so in my defence I was going off the BMW OEM numbers site that showed this:
with the bulb being number 4, which is listed as
04 Longlife bulb 12V 6W HALOGEN 2  10/2003 63217160795 $10.92
and when I googled 63217160795 it gave me
Thats my excuse and I am sticking to it
Now to get some bulbs  ;)
E30 320i
E36 325i Coupe
E46 330i SE
Now an E53 4.6iS
Ant
Re: LED Sidelights
Post by Ant » Sun Jun 02, 2013 12:17 pm
On Jayx5's advice about his from hids-direct I have gone with some of these:
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=370639893162
E30 320i
E36 325i Coupe
E46 330i SE
Now an E53 4.6iS
