Lads,
I know this topic is well covered elsewhere, I have now suffered the same fate, my front passenger door wont open from inside or outside. My question is about parts, what do I need, is it the bit that's inside the door? does the exterior handle normally get changed when this prob happens?
John
Quick one about door handles.....
- John
02 X5 3.0D Sport
Onlinegmc15
Re: Quick one about door handles.....
It's normally the bit inside the door only. On mine, a small bit broke off a part of the hinge on the part inside the door and I just repaired it with a small tie-wrap. When the other door want I had to replace the whole carrier assembly. Bit awkward to do possible if you are OK with a bit of car diy
x6 M50d
