bmw 1.4.0
Posted: Tue Apr 16, 2013 9:31 pm
by shadrack
so the only thing the m3 had when i bought was the tyre pressure light was on, after 2 new rear tyres were put on, i thaught no biggy ill just turn them off but i cant seem to access the menu to to this, thanks
Re: bmw 1.4.0
Posted: Tue Apr 16, 2013 9:42 pm
by Horizon
http://www.ebay.com/itm/170821713729?_t ... 97.c0.m619
The advert says it's good fo E46's, does it use the pressure sensor caps or the traction control to spence the low pressure, has it a button on the dash like the facelift E53?
Re: bmw 1.4.0
Posted: Tue Apr 16, 2013 9:59 pm
by shadrack
[quote="Horizon"]
it has a button to restet on the dash but i reset it then 5 minutes later its back on
Re: bmw 1.4.0
Posted: Tue Apr 16, 2013 10:07 pm
by Horizon
The tyre pressure section on the scanner refers to the old pre facelift system I think, so it probably won't highlight it on a scan, hence the reason you can't success it. I'm not sure which section the traction controlled system would be under without having a look through the menus.
