Hi All,
My front o/s parking light has failed and the indicator is constantly lit,i have Zenon headlamps.
Is this a DIY job to replace bulb,it looks like the headlamp needs removing to replace bulb.
Many thanks Rick
FRONT O/S PARKING LIGHT NOT WORKING
- Rick
2004 4.8is Le Mans Blue
Mods,Speaker upgrade to JL Audio C5 650 CSI Comps,Pioneer TS-WX77A subwoofer,Lazer Pro Park.
- x555
Re: FRONT O/S PARKING LIGHT NOT WORKING
Rick iirc you need to undo the headlight retaining screws (mark them so's to put them back the same)and then slide the lights forward to gain access to the indicator bulb.Not a great design
.....either that or you need fingers like ET
- Rick
Thanks x555 for reply,i have lost the parking light which i think is the ring of light around the low & high beam lamps,is this ring of light come from just 1 bulb
- x555
oops sorry fella i read the bit about the indicator and posted as i have changed them before......mental note take more time reading threads
Not sure on the parking light as i haven't done anything with them before.
Your parking light is the angel eye bulb as you said. Easy replacement. At the back of the headlight there is a round twist off cap. Undo this and you will find a halogen bulb. Just turn this bulb to release it. You might as well replace them with nice White led bulbs instead while you're at it, if it's broke...mod it - lol
- Rick
Thanks Raj,i have removed the round plastic cover about 50mm diameter but cant really get access as limited space,do i need to remove the headlamp ?
Regards Rick
Regards Rick
Need to check mine this evening as I think I removed the pipes etc behind the nearside light. To remove the headlight I had to remove the bumper.
